Question about Dryers
Whirlpool Dryer LGR7646EQ3 - Auto Dry is not working
We have a ten year-old Whirlpool dryer that is suddenly no longer working on the auto dry. Instead of shutting off when the clothes are dry, it just...keeps...drying... (we had a load go almost ten hours, thank goodness my husband happened to notice it was still going! I was distracted by our two little 'uns). The timed dry seems to work just fine. I have read a bit about cleaning the moisture sensors; trouble is, I cannot seem to find them inside the drum. Any suggestions? Thanks!
~Michelle
  • pop47_99 Oct 12, 2008
    Mine does same thing.in the auto cycle it will dry the cloths and the timer will advance about 1 3rd of the way then just sit and dryer just runs and runs.
    I took the timer out ran it on 110 and it cycled fine(no worn off teeth inside) Vent is not clogged and vent fuse is good
  • jonnyseed Mar 23, 2009
    My kenmore dryer is doing the same thing, and then sometimes tripping the breaker in the pannel before being able to restart. Replaced thermal fuse and is still doing the same thing. Where is this moisture sensor?
    Novelist:
    Champion:
  • 261 Answers
I went over the part list and I didnt see a sensor, if it is there it will be two silver wire bars either on the back bulk head or at front right just below the door, possibly your timer has gone south too.
The only item I saw was a dryer cycling thermostat that shuts off heat when a certain temp is reached, here is a link;
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2893&PPStack=1
Posted on Sep 16, 2008
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
Dryer isn't drying as well as normal.Lint filter is clean.Doesn't seem to work any different on timed dry or auto dry.I have electrical exp. but no dryer exp.What should i check and how do I access it?
i belive you should check the vent hose from the dryer all the way to where it exits the house... that's usually the problem when dryers aren't drying as well as they shoud... lint wil start to cake on the walls of the vent and either create a complete block or slow the air down enough to keep it from circulating like it should
Feb 14, 2010 | Whirlpool WED5300S Electric Dryer
The timer seems to not work only on the auto sensing (left) side. It does not move forward. On the timed dry, its fine. I'm thinking a piece in the timer assy is bad. Is there anything else that can go...
The auto dry sensor in the dryer could be bad or the wire to the auto dry sensor may have come loose. If these parts are OK and you are getting heat in auto dry then yes,it would be the timer.
Sep 29, 2009 | Whirlpool LGR7646E Dryer
Automatic Dry Function Has Stopped Working
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Sep 20, 2009 | Dryers
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Dryers Logo
872 people viewed this question
Top Dryers Experts
