For cuisinart food processors that won't shut off: with bowl off - not attached - hold OFF button down while plugging in. With a screwdriver or other implement, press the button that gets depressed on motor base when bowl is attached and snapped into place ( small flat rectangular piece that clicks the bowl into place. While still pressing OFF button, press this a few times times, unplug then release the OFF button. I tried several suggested combinations of button pushing and unplugging, and this seems to have fixed it!
SOURCE: My brand new Cuisinart 14
Make sure the bowl isn't locked in backwards !!!!!!!!!!!!!!!!!!!11
SOURCE: need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
SOURCE: Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
SOURCE: cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
SOURCE: Cuisinart Processor workbowl lid fitting
Yes, it will fit. There is also a DLC016B that will fit, but it does not have the feed tube. It's just a flat cover.
