Question about Compaq Computers & Internet
I have to wiggle my dc cord in order to get power why is that for my notebook
    Scholar:
  • 45 Answers
Hello ndy3,
It can be because the wire inside the cable is at fault, but the main reason (99% of the time) is because the end or either the laptops power input OR the plug on the dc power cable is not fitting snug enough. This can be fixed by either getting a new dc power cable or by adding a drop (and i do mean drop) of gold or silver (or even solder) to the rim of the laptops input. But you MUST be VERY careful when doing this and make sure that whatever you apply is just coating it. If you do it right then the plug will fit more snug and the problem will be solved.
Hope this helps.
Posted on Sep 16, 2008
Gateway MS2291 wont power up
Did you check the DC Jack where the Power Cord plugs into the laptop? If it is bad (wiggly or loose) then the laptop will not power on. Take an ink pen and put it where the power cord would plug into the laptop and see if the jack wiggles or is broken. If so, that's your problem.
The old power cord might be some good if the problem is with the DC Power Jack.
May 01, 2012 | Gateway Computers & Internet
My M2000 will not power up, have new battery and charger but still no power.
The DC jack in the laptop is often source of trouble, but the computer must be dismantled down to the motherboard level, at this point I recommend a professional to assess the repair cost.
Apr 08, 2012 | Compaq Presario M2000 Notebook
My girlfriend walked by my asus 1015pem and her foot caught the cord and tugged on the netbook pretty good. the plug in/out of the battery cable still functions and charges properly, but there does seem...
You are very lucky the notebook did not bounce!
Yes a small amt of wiggle is normal. I would advise against "checking" it too much. (Applying more wiggle may not help the situation)
If at some future date you experience issues with keeping power connected, you will know what to check first. I think you'll be fine.
Feb 09, 2011 | ASUS Eee PC 1000HA Notebook
Power cord when connected to laptop does not power up. There is no teltale sign of damage to power cord. There is a slight wiggle of the male prong when inserted in the 12v circle socket. Could it be the...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Computer works by Battery only but not A/C cord
Your DC Jack Is Most Likely Failing From What You Describe....
The DC Jack Is The Port Where Your Charger Cord Plugs Into..
If Wiggled Enough, It Will Pry Loose From The Motherboard And Eventually It Will Begin To Short Out The Power, If Left Unrepaired, It Will Eventually Lose All Means Of Charging/Powering On Due To The Solder Being Burnt Away From The Positive Pins That Connect To The Mainboard....
You Might Want To Test Your AC Adapter With A Multimeter For Positive Power and Correct Voltage .. Sometimes A Broken Cord Will test Good If The Break Is Making Contact when testing....
So When Testing the cord... Slightly wiggle it to see if indeed there is a break in it or not...
Feb 06, 2009 | Gateway 450ROG Notebook
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Dell D800 Startup problem
No, it is a DC Power Jack issue,,,it sounds like the +positive Post on the jack has wiggled loose from the mainboard..you can tell by pluggin in the AC Power cord and wiggling the plug if you see the power light coming on and off.. it's a Loose DC Jack,
If it doesnt do as i just described, and it won't power up at all, it is the motherboard.. and will need to be replaced.. Another Possibility is that it is Stuck in Sleep Mode.. Hope this helps you ..
Jun 03, 2008 | Dell Latitude D800 Notebook
Screen blackout when using AC cord
I think you're goin to have to replace your" dc-jack" as it's called. This is where your AC cord plugs into your laptop.DC-jack problems are very common in laptops.Over time they wiggle loose just enough to mess up the solder connection on the motherboard.Try gently wiggling your AC cord where it plugs into your computer ,if you screen returns to normal when you wiggle the plug a certain way,then you've most likely got a bad dc-jack.
Feb 12, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
