Question about Sharp LL173C 17" Flat Panel LCD Monitor
Lcd monitor will not stay on
I have a sharp 17" ll-t17a4-b picture never stays on all ways flash on an off will never stay on can you tell me what i can try
  • Jerry Shockley Jan 27, 2009
    My 19" lcd monitor will turn for just a second and then go black.
    My wife said she saw a bright flash, then the screen went black. I am running two monitors so I tried the other cord, still didn't work.
    I plug it into my laptop same thing happened, when I turned it on it came on for a second then went black. Does any ony know what might be the problem. Thanks the Shock
    Genius:
  • 1,019 Answers
First thing to try, is to check the cable from Monitor To PC Or Graphics Card.
If you have a loose-broken internal wire, this will be the problem. Dry-Solder Joint et,c.
If the cable, has a socket either end, from monitor to computer.
try to obtain a replacement cable. The second option is to test the output source. i.e Graphics card or output to the monitor.
Hope this helps Mike @ Compurepair.
Posted on Sep 16, 2008
The stand, attached at the back of the screen, has snapped and needs replacing. Can it be replaced and where can I get one. the screen is fine.
Try contacting Sharp. Places that sell them may have one laying around but I doubt it.
If you can't get one, check the middle of back of the monitor for 4 screw holes (empty) in the shape of a square, they're for attaching to a wall or desk mount.
An example of a desk mount:
http://www.google.co.uk/products/catalog?q=monitor+mount&cid=392981540399473061&ei=3uNbTciZNJe5-QaMn62VCQ&sa=title&ved=0CDQQ8wIwCTgA#p
Feb 16, 2011 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sometimes the screen goes blank and today when I restarted the computer the screen is flickering very lightly.Does this means its going?
The picture board on your monitor is bad, since the power led or button is on and all connection are corrrect, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jun 30, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
I need to find drivers for a Sharp LL T17A4-B 17 in. Flat Panel LCD Monitor. I recently changed it to a different tower and cannot find the driver for it.
Hi
Thanks for using FixYa. You can download its drivers by clicking on any of these two links:
Sharp LL T17A4-B Drivers
Sharp LL T17A4-B Drivers-2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 08, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
LL-T17A4-B incompatibility with OS
go to the add a--- section under the control panel and right click on the monitor/s
click on the properties tab and then click on the compatibility tab
tick the box and click on the os you want for that computer
click apply and ok
in that properties you will also find a drivers tab , click on that and then the driver update line
it will search and download the latest drivers or come back with a message that the driver in use is the most appropriate one
Mar 27, 2017 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp ll-t17a4-b backlight
when ever i try to sign in the messanger says erorr code 80072efd how can i solve this matter
thanks
jem
Oct 21, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Back light
I would suggest Tritronics for the service manual and the replacement parts. Unless you have a service manual, it takes a lot of disassembly by careful observation (or trial and error) to determine how that delicate LCD panel is put together! http://www.tritronicsinc.com Of course I'd want to be sure that the problem is not in the inverter instead since that's a much more common cause of backlight trouble. Unless you happen to know it's one or more CCFLs, then of course you'd want to replace them all since they have the same aging.
Jan 14, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp LL T17A4-B (Black) 17 in.
Are you using the digital connection?? If so try using both the analog and digital connection then set the digital as the Main monitor in your graphics card interface. To check if the backlight is out, darken the room, and light a flash light into the screen. If you can see a picture, then you need to replace the backlight. Good luck
May 03, 2006 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp LL173C 17" Flat Panel LCD Monitor Logo
136 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
