Question about Car Audio & Video
Help! i got a mtx thunder 2301 amp! for some reason it keeps blowing my car fuse! why is it doing that?
  • lj_rmn Sep 17, 2008
    i tryed it and it only throws spark!
  • 35 Answers
You probably need to run 4 gauge wire if not already done so, and check the fuses on the amp, add the fuses together then buy the right fuse rating for the fuse connected under the hood
Posted on Sep 16, 2008
  • Carder09 Sep 17, 2008
    Then your set up is completely wrong and you need to disconnect all wires and when you put a better fuse to the battery compartment then rehook the wire to the battery and make sure that its not connected to the amp, after that THEN connect the wires to the amp leaving the power wire last and that should work then,
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
THE AMP TURNS ON BUT THE FUSE UNDER THE HOOD KEEPS BLOWING and the sub wont turn on but the amp turns on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Please use volt meter to test correct voltage and ohm feas ng on speakers. .A thumbs up would be greatly appreciated if this answer is helpful to you. amp-turns-but-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 16, 2011 | MTX X Thunder 1000XD Car Amp
How can i hook up a second battery to my MTX 4105d amp
well the best way is keep the amp hooked up how it is now and on your amp there is a + and a - for a cap hook up the negative to the negative for the battery and the positive to a fuse like with a 60 amp fuse then the other end of the fuse link goes to the battery
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
All right I'm having EXTREME problems with my car stereo. Not only have I talked to several car stereo advisers, and also mtx advisers I have also talked to Crutchfield advisors and no one has solved my...
Don't give up yet, I'm sure we can find an answer. With car audio, as with any do it yourself project there may be just some small thing you are missing.
Oct 10, 2008 | MTX Car Audio & Video
Fuses
check you spkr wiring in put if they are cross
May 25, 2008 | MTX Car Audio & Video
My amp doesn't turn on...
If there is a zero ohm connection across the B+ and ground terminals, it should blow the fuse as soon as you apply power.
Oct 10, 2007 | MTX Thunder TA7801 Car Audio Amplifier
MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
