Question about True TD-50-18 Beverage Cooler
True TD-36-12-S Bottle Cooler
When it is turned up as far as it will cool, the beverages are still not cold. Is there something that seems to go wrong with these. This was bought 12/02/05
    Guru:
  • 462 Answers
1st check the outter coil and make sure you can shine a flash light through the coil. If not blow out with compressed air and look again. A dirty coil may be your problem.
2nd check the inside coil it may be blocked with frost - ice
3rd the fan both in and out have to be running.
4th check the door seals
you could be low on refrigerant or have a bad thermostat but eliminate all else before going to these 2 problems.
Posted on Apr 26, 2009
    Problem Solver:
There are no service valves, to check charge
Posted on Apr 29, 2009
How do you change a evaperater fan on a Beverage air bottle cooler?
Its a pain but reach down in there and pull the screws out and remove the panels. Its in there honest! Hope this helps good luck.
Jul 12, 2014 | True TD-50-18 Beverage Cooler
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
True TD-95-38-LT Beverage Cooler wont drain , cannot locate drain plug
Usually inside the compressor compartment, below that is the collection pan, blow it out with compressed air
Feb 01, 2013 | True TD-95-38-LT Beverage Cooler
Why did my unit stop cooling beverages?
my skybox run but my beverages is not getting cold,can you tell me what i need to do,or where i can i take it to get fix?
Nov 15, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
What are the two red led lights on a skybox circuit board for? Mine are lit up and the unit won't cool. Is that an indication of what is wrong? If so, any idea what it is?
The red lights on the board indicate it is working properly. The purpose of the board is to control the dispensing of the beverages, and has nothing to do with the cooling process. You have a cold control (thermostat) inside the refrigerated area. The cold control is like a switch that sends 120vac to the compressor when cooling is needed. The failure of the unit to cool would be either a bad cold control, compressor, or compressor start relay. Testing of live electrical circuits should be left to a qualified service technician.
Oct 05, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
The kegerator will not get cold. It seems to cool slightly but it wont get cold any longer. It does sounds like the compressor is working .. i hear it turn on and off as it did when it was working...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Beverage-Air BEVBM23 Commercial Beverage...
My danby beverage centre does not cool anymore 3 years old. compressor is hot. fan sounds and appears to work well all coils are clean.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101 ,.,
Oct 06, 2010 | Danby DBC514BLS Silhouette Beverage Centre
Yes I have a True 95 38 Beverage cooler and I bought it new 4 years ago , I have used it for 3 and 1 year it just sat not running , well I plugged it in the other day and it is only blowing warm inside and...
Could be many things... A bad thermostat, bad compressor, bad compressor start relay, refrigerant leak, moisture in the system, or even a blocked capillary tube. You would need a lot more information... mostly only the kind a technician can get by getting his hands on it. Sorry.
Sep 11, 2010 | True TD-95-38-LT Beverage Cooler
Rear interior wall of the beverage center freezes. 2 inches of frost accumulates on the rear of the interior. The box described as auto defrost. Uneven cooling of drinks. Some are froze on some shelves and...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Refrigerators
The motor and fan run but the air is not cold
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 20, 2010 | True TD-50-18 Beverage Cooler
True TD-50-18 Beverage Cooler Logo
295 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
