Question about Whirlpool GEW9250 Electric Dryer
Has power, light in drum, Control button will not work
Anyone know what to do? The manual is useless. I have cleaned the lint traps, checked all the circuit breakers and have no clue where to go next.
Mahalo, Kula Joni (joni@tropicalvacationstravel.com)
  • cfister2 Sep 24, 2008
    has light in drum, has power. Manual timer works, but will not tumble. When start is pushed, the dryer clicks on, but no tumble. Any suggestions?
    Vicki
    Lakeside Park, ky
  • johnt2489 Nov 02, 2008
    I have the same problem. All the buttons and lights work, but when I push the start button, it clicks, but nothing else happens. The timer continues to count down.
    Novelist:
    Champion:
  • 261 Answers
Aloha, Here is the Kama aina answer for dis one brah. The control panel is all pau or the serial cable no can. Unplug the machine fo 30 minutes an trace the cable back to the ccu and unplug an re plug the connection. Bumbai and it no work then the panel pau, ok?
Posted on Sep 16, 2008
Panel powers up, no codes, but the drum will not turn over.
Problems could be related to defective control board or control panel as it is very common issue with these new dryers with to much electronics and made to fail parts
Feb 26, 2015 | Samsung DV330AE Dryer
Beko condenser dryer
check dampness senser may still have lint trapped around it
also poss. stuck button on control board
Dec 06, 2013 | Dryers
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
LG2701V stopped working after lint trap was not in place
Pull the dry out and clean (UNPLUG IT FIRST) out the entire exhaust vent system..
Sep 20, 2017 | LG DLE2701 Electric Dryer
I have a kenmore elite model 110.8586 or 8587 anyway I cleaned my lent screen put it back as I always do after every load and know it say check lint screen
Possibilities
The sensor is dirty..remove the lint trap and clean the orifice with a Swiffer duster. Dryer sheets can clog the lint trap use a tooth brush and detergent to clean the lint trap. Alternately see if it presents the same issue operating it without the lint trap. If you have an air compressor blow out the slot too. Make sure the main exit hose is cleared also *vent duct*. Tip the unit and blow the air in too.
Or a melting type fuse mounts on the blower housing and is tied into the same circuit as the door switch. When it melts it shuts down everything and this keeps the lint from catching fire.
Also check the belts.
You can turn off the beeping if you would like. Instructions are in the manual. By Pressing the buzzer button it has Loud medium low and off positions.
Remove the rear vent and try the unit...
I'm thinking that your sensor is probably the issue here.
Jun 10, 2011 | Kenmore Dryers
Bosch Nexxt 500 washing machine. wfmc3301uc/06 start pause light blinking and machine wont start.
According to the manual, if the Start/Pause button light is blinking, it means the Start/Pause button was not pressed. Press the Start/Pause button. If this fails to work, you may have a faulty control panel, preventing the Start/Pause button from sending the signal to start the cycle. Try unplugging the washer for 5 seconds, plug it back in and try again. Let me know if you come up with any Error Codes and I will further assist you.
Mar 19, 2011 | Washing Machines
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
My dryer heats,tumbles,but takes several cycles to dry a load(small).Not much air coming out of vent and have cleaned vent out.Any ideas?
The fan that pulls the hot air through the dryer and pushes the exhaust out through the vent hose is plugged with lint. You will want to remove the cover on the fan and manually clean the fan out. I had the same problem with my dryer, I was astounded by the amount of lint that was trapped in the fan.
Also look inside the cloths drum on the back wall and make certain the hole in that wall are not clogged with lint also. Use a flash light and make sure the hole are perfectly clean.
Good luck, clean it all out and let me know.
Regards,
Sep 09, 2009 | Maytag Dryers
LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Aug 25, 2009 | LG DLE2512W Electric Dryer
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
