Question about BenQ DV3070 30 in. LCD HDTV
Tv code for 30" benq TV
I have bell expressvu and can't find the 3 digit tv code to program the remote for the benq 30" TV
  • marc51000r Dec 07, 2008
    i have the same problem with my benq 40" plasma
  • gencilena1
    gencilena1 Jan 04, 2013
    i nead the code of the BENQ
    New Friend:
I nead code of the benq
Posted on Jan 04, 2013
3 Suggested Answers
SOURCE: Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
Posted on Feb 05, 2009
  • 11800 Answers
SOURCE: I just bought an RCA
If you have tried all RCA codes from the manual then your only remaining option is to perform a code scan - maybe one of the codes meant for another brand will match your tv.
Posted on Oct 11, 2010
I need a code number for a DAENYX TV ihave a remote philips brand number sru5107/27 All so will the remote for bell expressvu work for for HD expressvu the remote belongs to model 3200 express vu
I have provided instructions on programming the remote to your Dynex TV. I have included the codes for your TV. We do not have codes for the Universal remote. You need to contact Phillips to see if they have codes that you can use. I hope this helps.
Address remote to TV:
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote codes: 720, 115, 969, 111
Ray Calo
DISH Network
Apr 12, 2011 | DISH Network IR Remote Control
I need a satellite Bell express Vue code (3100) I can't use the remote control Dish!!!!
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 23, 2010 | DISH Network IR Remote Control
I need 3 digit code for my Prima tv to program bell express vu
Dec 16, 2009 | Prima C2012 TV
Need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Jan 27, 2009 | Jensen 143307 Remote Control
Device Codes
UNIVERSAL REMOTE CONTROL CODE LIST We have compiled a list (below) of codes for Universal Remote Controls. .... EXPRESSVU 464. FUJITSU 760 860. GE 265 863. GENERAL INSTRUMENTS ...
dogbytecomputer.com/codes.htm - 34k - Cached - Similar pages see if you code is in here.like my dishnet.remote,some no namebrand tv's just can't be controlled by other remotes
Nov 14, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
Feb 14, 2008 | DISH Network IR Remote Control
Code for satellite bell (expressview)
Jan 03, 2008 | Televison & Video
0 - second TV
Oct 22, 2007 | Televison & Video
BenQ DV3070 30 in. LCD HDTV Logo
237 people viewed this question
Top BenQ Televison & Video Experts
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
