My 04 jeep grand cherokee is smoking from the radiator. the radiator fan doesn't appear to be running. i've had to put more and more coolant in the resivior because it keeps going right through it...
well,probably needs radiator replaced,burning off fluid smoking problem?if not going out exhaust or in oil,have radiator checked-replaced,if fan not running check relay and fuses,might need fan replaced,if you overheat engine to bad you will blow head gaskets and this is costly.check your oil,see if gray and milky,if so blown head gasket and water-antifreeze in oil,if going out exhaust will be blown head gasket inbetween the cylinders,fix radiator and fan first,but check out to see where all fluid is going.
yes i had. valve job done on it.
i had 1990 geo metro 3 cylinder blue smoke comeout through mufler.its bad smelling,gas millage reduced
