Question about Maytag Washing Machines
How to change a drain hose connector on a maytag washing machine
    Novelist:
    Champion:
  • 261 Answers
Ok, which model and is it the entire hose?
Posted on Sep 16, 2008
I have a maytag bravo and it making a humming sound and wont drain water
There isn't much I can add to Gordon's Appliance solution.
thats exactly where I'd go for the solution .
Dec 11, 2014 | Maytag Bravos MTW6600T Top Load Washer
I have a old maytag washing machine that drain hoses needed replaced got new ones put on and it half kinked.so now it will not drain right what do I do
The replacement drain hose may have to be replaced with a replacement drain hose maybe of better quality (non-kinking) or connected and routed to avoid kinking.
Apr 19, 2014 | Maytag Washing Machines
Maytag washing machine no water coming in
check water coming out of hoses. check on hot and cold fill. could be fill valve
Feb 09, 2013 | Maytag Legacy MAV208DAWW Top Load Washer
Maytag Atlantis washer drain hose is over flowing during rinse cycle
It probably has some coins stuck in the pump or a kink in the hose. If the washing machine won't drain, remove the access panel, and follow drain hose into machine and to the pump.You will need something to catch the water. Take pliers and sqeeze clamp and slide away from pump. Pull hose off and drain water. Remove coins from pump inlet and reassemble. If it is overflowing where it drains into the wall, you will need a pipe snake or a plummer.
Dec 29, 2012 | Maytag Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
My Maytag Bravos quiet series 300 washing machine stopped. Won't drain. A message Ld shows. Not sure what to do
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test
Mode, and perform the Manual: Pumps
test.
2. Remove the console to access the machine/
motor control assembly. See Accessing
& Removing the Electronic Assemblies.
3. Visually check that the P4 connector is
inserted all the way into the machine/motor
control.
If visual check passes, go to step 4.
If visual check fails, reconnect P4 and
repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1.
If resistance values are good, go to step 7.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem
exists in the motor winding or in the connection between the machine/motor
control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom
of the machine and the pumps. See
Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and
take measurements across pump terminals. Measurements should be as shown in the wiring diagram.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the
pump motor.
If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/
motor control. Repair or replace the lower wiring harness.
If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check
the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed:
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Perform the Manual: Pump test.
Nov 21, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
How do I drain a maytag washing machine?
If the machine will not operate to drain the water, gravity will do the job for you. Simply remove the drain hose from the standpipe, and lower it to a floor drain if one is near enough to the machine. If no floor drain, you can catch the water from the hose into a large bucket for disposal. You will need to empty the bucket numerous times before the washer is empty.
Jul 15, 2009 | Maytag MTW5900TW Top Load Washer
Maytag washing machine PAV3360AWW Won't stop
Your inlet valve is defective, can be easily changed by you. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Is it when you turn on the machine, if this is the case check to see if the exit hose behind is approx 3 feet (it should be) above the ground, & then goes down to the drain. The hose should not go into a drain at floor level.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 02, 2009 | Maytag Washing Machines
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
