Question about Canon EOS-AE-1 35mm SLR Camera
Shutter speed lagging.
My canon ae-1 started having this problem about a year ago out of nowhere and was working fine before that. no matter what speed it is on, it lags so much that the pictures just come out black, it makes a weird noise, sounds like somethings sticking?
  • 667 Answers
There is a common problem that most A series Canon develop with age. There is a small set of gears that govern the speed of the mirror rising. One gear is brass and becomes dry, (lack of lubrication). You should have the camera serviced by a repair person or there are kits available to DIY. You can find the kits on eBay
Posted on Oct 09, 2008
Black line from bottom to half way up camera which gets higher as i increase shutter speed
Chances are you're using too high a shutter speed. Here's a link to understanding how that works. Good luck!
High Speed Sync Flash
Jan 09, 2013 | Canon EOS-AE-1 35mm SLR Camera
My A1 only works when the lens is off the "A" position. Manually setting the apperture it works fine, otherwise it displays a bunch of EEEEEEEEEs....
The AE-1 requires, that when the camera's shutter speed dial is set on A or Auto, that the lense must be set on the highest aperature (22, 32, whatever that lense has). In all other settings you can move around however you'd like.
Aug 14, 2011 | Canon EOS-AE-1 35mm SLR Camera
Aperture setting and shutter speed together?
Yes it does. Check your manual. If you don't have a manual you can get a pdf download from canon. This link should get you there. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=214&modelid=9429#DownloadDetailAct
Sep 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Shutter Speed
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
Sep 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shutter stuck on Canon AE 1
Just now saw your problem.....I can repair this for you. No it's not "overwound" you possible have some small piece of plastic that caused your second curtain to get hung up and thus jam the entire camera. I have probably repaired 500 AE-1's with the same problem. Art www.flcamerarepair.com
Nov 22, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon ae-1
To open the back pull on the rewind knob ( pulling up ) until back opens. Check that your 6 volt battery is ok ( ae -1 has an electronic shutter so will not work without a battery ): battery situated on the left hand side of the camera ( if it is facing you ) underneath small flip up door ( lock is at the bottom on the left of the small door ) . Check the battery by pressing the shutter release gently and seeing if your light meter needle moves. No movement ? replace battery. You have two modes for taking pictures : auto which is actually AV ( aperture priority) or full manual : both are set by moving the shutter speed dial on the top right hand side ( underneath film winding lever ).
Sep 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Shuuer stuck down, lever wont advance
The Canon AE-1 has an electronic triped shutter and cocking system and requiires a battery to function. So yes the battery is required. Goog luck!
Aug 26, 2007 | Canon EOS-AE-1 35mm SLR Camera
Shutter Only Fires at 60
Remove transport/winding lever and loosen the retaining ring underneeth. Gently lift shutter speed dial and reseat it. Tighten the retaining ring and reattach winding lever. ( the shutter speed dial is not engaging the mechanism inside the camera and you need to establish proper connection ).
Aug 24, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
81 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
