Question about Lexmark Office Equipment & Supplies
Unable to print from LexmarkX125. Faxes come in fine. Need to install printer back on computer. Somehow got deleted. Need to downlaod software so able to print.
  • 109 Answers
Go to www.lexmark.com and click on DRIVERS AND DOWNLOADS. Then use the DRIVER FINDER. In SEARCH BY MODEL, type in x125 and you can choose a driver from there.
Steve
Posted on Sep 16, 2008
My printer is connected and ready to go but it wont print. my computer says its printing but nothing prints.Then it will say error. how can i fix it?
Hi
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
May 13, 2011 | Brother HL 2140 Laser Printer
Errors
solution 1>
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Nov 02, 2009 | Computers & Internet
J6480 fatal error 2753 MSI.dot4wrp during full driver install. I tried uninstalling al related hp drivers, all the HP advice. Disabled firewall, services etc. Do you have a solution that works?
you can try with installing the windows installer 4.5 and then try.. otherwise reinstalling windows might work because the error you are getting is related to installer.. and its a service of windows itself which is responsible for all the software installation..
Oct 29, 2009 | HP DeskJet 648c InkJet Printer
My printer is not responding to my computer.
Go back into Printers and Faxes, delete your printer icon, restart your PC and reinstall your printer driver. Good luck.
Jul 01, 2009 | HP Hewlett Packard Officejet 7310 InkJet...
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
SOLUTION:
Steps:
solution 2>
then go to msconfig
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
I can not install my HP Printers Officejet-- gives fatal error
This issue requires some serious trouble shooting and solutions cannot be posted as they are too long.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
Jun 03, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
No Printing
You need to uninstall the software and delete the printer through the Start>Printers and Faxes window. (Right click on the printer and select Delete.)
Disconnect the usb cable from the printer and reboot your computer.
Begin from the beginning and only connect the usb cable when prompted by the software.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
I lost installation cd and need to downlaod software and driver for lexmarkx125 series all in one printer
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:346:0:0
download the driver here
Mar 10, 2008 | Computers & Internet
HP L7680 All in one will not send faxes from PC S/W interface
After much thrashing, here is the solution to the problem. Somehow the printer drivers lost coordination with the corresponding Windows supporting programs. You would think that reinstalling the printer drivers would fix the problem, AND IT DOES, but there are 3 tricks:
· Uninstall everything associated with this printer with the install disk in the computer (this may really not be necessary, but it worked for me). [This is also the solution when the a window comes up asking for TrayApp to be inserted using a disk—they mean the hp install disk].
· After the un-install, MAKE SURE you ALSO delete the printer using the control panel. This is critical. If this doesn’t happen, the corresponding Windows software is somehow hooked to the wrong thing when the reinstall happens. Then reboot the system.
· Install the new drivers with the printer off, and the USB disconnected from the printer. Reboot the system [not sure the reboot is necessary]. After the computer has booted, connect the USB, and power up the printer. The computer will recognize the printer and put the printer icon in the Control Panel.
It turns out that correcting the driver mis-coordination by BOTH uninstalling the printer drivers and taking the printer out of the control panel, then properly reinstalling solves BOTH the fax problem, and the protection fault problem! Amazing such a little thing can make such a difference!
Jan 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
Printer stopped working claiming the jobs have been 'stopped' and giving no explanation.
Hi Plug out the usb cable from the cpu. Try deleting the printers from the printers window(START, Printers and Faxes), uninstall the software. Power off the printer and unplug power adapter. After the printer has been deleted from the printer window, plug it back in and reconnect back to computer. Then try a new installation of the printer and software. The pending documents that have been stopped should now not be in the spooled documents.
May 02, 2007 | Epson Stylus DX4200 All-In-One InkJet...
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
