Question about Acer AL2216WBD LCD Monitor
22" Acer flat screen monitor
The display seems to vibrate and have some kind of interference causing the the script and pictures on screen to appear to be vibrating. when changed to a regular monitor this is not going on so I think I ruled out interference from an external source. I also tried to connect the Acer into different power outlets to see if this would alleviate the "interference" with no success. I have only had this monitor for about 2 years..
  • Abhinab Choudhury Oct 23, 2008
    hi I have the same problem............
    Genius:
  • 1,019 Answers
this sounds like an electrical fault or failing component, within the Monitor.
Check the cabling, to ensure it,s not damaged-broken-kinked et,c. by carefully moving the cable gently side to side and up and down.
If it puts itself right for a second or two. you can assume its a broken internal wire, within the lead.
Or a dry soldered joint-Connection.
Mike @ compurepair.
Posted on Sep 16, 2008
Samsung ln22a450 no picture just audio in the back
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Samsung LN22A450 22 in. LCD HDTV
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
RCA flat screen TV turns off by itself and won't turn back on
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | RCA L22HD41 22 LCD TV
My friends flat screen monitor started to vibrate the other day. I had her check the cables but still picture vibrated. No obvious sources of interference so she bouhgt a new monitor. Same problem.She...
If you have tried increasing resoulution as well as refresh rate then,
Try to use TFT, I hope a strong High tension wires may be near your house. (TFT's are less affected by this interferences)
Sep 11, 2010 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
I just bought a Acer P191W 19" flat screen monitor. My problem with it is that the sides and bottom half of the srceen are pure white and the rest is a bit too bright and faded.. I need help to fix this...
Do you have any speakers or a fan (table top fan)  of any kind near your screen?
They may not be the shielded kind and may cause magnetic interference.
Have you checked your monitor cable to make sure that none of the pins attaching the cable to the monitor or the PC has been bent?
Please post here to let me know how this turns out.
Thanks,
Kaj
Dec 17, 2008 | Acer Computers & Internet
Acer x223W Monitor issue - not displaying correctly in native resolution
hi, when all connected press and hold the FN key on the bottom left of the keypad while pressing one of the function keys F1 to F12(the one with picture of a screen or monitor). You may need to press it more than once but if will eventually switch the display over to the tv
Hope this help
May 30, 2008 | Acer AL2216WBD LCD Monitor
Distorted picture
It's possible your video card or monitor is going bad. Which type of monitor do you have? If it's a CRT then my guess is....monitor.
Check all your cables and connections first.
If possible hook up a known working monitor to rule out memory or video card problems.Monitors have a refresh rate but I don't
recommend doing this without supervision or complete knowledge.
Check to make sure you don't have any interference close to your monitor. Interference would/could be: magnets/speakers/radio's/televisions/microwaves (not sure about micros.
If your have a LCD monitor I'm not sure all these suggestions apply.
Sep 14, 2007 | KDS Radius RAD-7 17" Flat Panel LCD...
Acer AL2216WBD LCD Monitor Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
