Question about Linksys Wireless-G Broadband Router
Password I have a linksys that I am trying to connect to my new laptop to access the internet wireless.......my son-in-law gave me this linksys but he forgot the password...what do I do?
  • SOUP2094 Jan 02, 2009
    My older daughter passed away and we are trying to hook up an IPod touch to it. when she was killed she took the password with her. I need help with changing her password.Please help me.
    linksys wireless G broadband router
  • Linksys Master
  • 6,487 Answers
Since you forgto the password the best way to make this router work fine is to reset it and reconfigure it back, To reset it just press and hold the reset button for 15 seconds while the power is ON, then if you still have the setup CD just run and that should take care of everyting, but if you don't have the setup CD you can manually configure it by accessing the router setup page if you're not familiar on how to do that better call LInksys tech support and let one of their tech walk you through with that process they are open 24/7 this is the number 800-3267114..........
Hope that helps............
Posted on Sep 16, 2008
I am trying to add a wireless connection to another laptop we own but apparently cannot access www.linksysfix.com/ela
Its not necessary to access linksys.com Your new laptop if has wireless card will read network automatically and connect with password if you set up for your router. If no password set up then your laptop should be online as soon as its powered on!
Most router problems can resolved by power cycle.
Check if your laptop new has wireless card and is enabled!
Sep 12, 2011 | Linksys Wireless-G WRT54G Router
Need help setting up the Sudenlink Modem to Linksys Router
Connect lan cable from modem to linksys router's WAN port.
Then configure linksys router with below method.
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set as your internet service provider settings like static ip address.If service provider give you user and password for connect internet then set router in pppoe mode.
Enable DHCP.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 18, 2011 | Linksys WRT160N Wireless Router
I CANT REMEMBER MY PASSWORD for my internet access, have got a new laptop and cannot connect
TO GET THE WIRELESS PASSWORD
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer
Step 3 : Default password is admin
Step 4 : Click wireless
Step 5 : Choose wireless security
Step 6 : Here you can find the Password
Step 7 : Try to connect with this password
let me know if this works
Regards
TOM
Dec 26, 2010 | Linksys Wireless-G WRT54G Router
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
Feb 27, 2009 | Actiontec (GT704WG) Router
Can not get the second laptop on the internet with the wireless
The post says he has a router "linksys wireless-g access point router" ???
If it is only an Access Point then Joed is correct you need the router to access your broadband with more then 1 PC
If you have a wireless access router then here are the instructions:-
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
If there is no security I would set it to WPA or WEP then the original computer connecting will need this value if it is connecting wirelessly
Dec 26, 2008 | Linksys Wireless-G Broadband Router
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Password
i think its wep or wpa password which u created in teh w/l router>connect a pc through hard wired on teh routers ether net port>and open a explorer>and in address bar type-(192.168.1.1)>enter>
user name--- admin- all lower case
password---- admin- all lower case
click on wireless-and click on wire less security>and change teh wep or wpa password and click on save settings>and reboot the router as well as laptop and use teh new password which u changed>rate me solved if its works
Nov 06, 2007 | Linksys Wireless-G WRT54G Router...
Wireless network
He might have specified and configured your laptops IP to his Home IP.
This is easily fixed by:
Open Internet Explorer > Tools > Internet Options > Connections Tab > LAN Settings > check the Automatically detect settings
Also you might want to check:
Start > Control Panel > Network Connections > Right Click on a Connection > Properties > Select Internet Protocol (TCP/IP) then make sure its set to Automatically obtain IP address.
*note* do this for your home one and delete your son-in-law's connection. If you don't know which is which just leave them and see what connect's then delete the others.
Nov 03, 2007 | Telco BATM Titan T4 (BTI-0430DC-L3) Router
Linksys Wireless-G Broadband Router Logo
80 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
