Question about Rockford Fosgate Punch P550.2 150W x 2 Car Amplifier Car Audio Amplifier
Power fluctuations I have this Amp hooked up to 2 12's type r subwoofers. they hit pretty hard and then sometimes they hit really hard. I mean they sound fantastic. But its only for a couple of minuites and then it goes back to just a decent amount of bass that Im used to. I cannot replicate these situations regardless of remote settings, lights on lights off...etc..etc. If you need more information I can find it out. Me and my friend put this installation together and its just driving me insane! thankyou in advance! -jj
  • jjstanman69 Sep 17, 2008
    Ok I left out information untill i looked at it thoroughly. I completly checked every fuse, rewired it to this diagram which matches with the subs that I have ( bottom). The only problem I found was the Fuse between the battery and the amp had minor corrosion.The alternator was running a little over 14 volts, the battery at 13. The 100Amp fuse was a little over 13 volts and so was the terminal of the 4 guage wire from the battery to the amp. The temperature is not a problem because its inside my truck compartment and while im driving listening to it the tempatures never exceed 80 degrees, also the amp runs very cool ive never fealt it to be to hot to the touch. I also checked the ground to be completly sure that's not a issue compacting the bigger problem. Im gueesing tghe next best thing is a capacitor. Meh.... mabey this helps J.J.
  • 35 Answers
This is due to a few things, Your amp, the tempurature in the car, the size gauge of wire, and the alternator, When your hittin hard bass and you notice over time it kinda dies out, it means that your sub is losing power cause of the lack of power your battery and alternator produce, If the amp is fairly big then it needs alot of power to keep it at peak performance, I would recommend getting an capacitor that is well suited for your amp, this will give you the constant power you need and the bass will always stay bumpin hard for a significant amount of time, Also the tempurature greatly affects the performance of amps cause the hotter it gets the less power it delivers then possible shut off where then it will cool off for a brief moment then return for only a litle while if still bumping
Posted on Sep 16, 2008
Popping noise
Check the sub with a multimeter. It should read the ohms it is rated at when you hook it to the positive & negative inputs. It its off your coil if bad.
Mar 16, 2013 | Alpine SWR-1241D Car Subwoofer
They speakers, when they hit hard they make this odd... smacking sound.. Also on just like.. eminem songs and some rock songs that I listen to whenever the subs hit the vocals get distorted, but when I...
Well it sounds like you need a mono block amplifier for the subwoofers. Subwoofers are ment for low frequency. If you try to run regular audio through the subwoofer the sound will become distorted at a high volume. If you have a crossover on the amplifier try putting it on LP. Also do not exceed the RMX rateing on the subwoofer because if you do they will also distort. If you try adding the mono block on to it and it is still doing it you may also be running to much power to the subwoofers.
Jun 13, 2011 | Alpine SWS-1043D Car Subwoofer
When power is applied, one sub hits fine and the other looks like its being pushed out really hard, continuously.
sounds like the amp is sending dc voltage to the sub. you probably have bad output transistors in the amp.
Mar 09, 2010 | Alphasonik PSW410 Car Subwoofer
Type rs not hitting
sometimes RCA cables to the amp can go bad give them a look-see they may need to be replaced. I doubt you have a problem with the speakers themselves. you may also check the ground wire to the amp, make sure it has a tight metal to metal connection
Oct 06, 2009 | Alpine SWR-1022D Car Subwoofer
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
MA Audio MA 1200XL Car Subwoofer
that subwoofer has dual 4ohm voice coils, if your amp can handle 2 ohms, you would put a wire from the positive (+) on the amp to the positive on both connectors on the sub, then hook the negative (-) on the amp to the negative on both the sub connectors that will be a 2 ohm load on your amp make sure your amp at 2 ohms is not more than 600 watts RMS or 1200 max.
Jan 01, 2009 | MA Audio MA 1200XL Car Subwoofer
Subwoofer wont play
Check your rca cables they might be loose or not connected to the amp or the radio. Sometimes those rca cable outlets get worn out by being bumped, moved, hooking up and pulling out connectors. Plug in your rca cords and wiggle them on the amp while radio is on and see if the music cuts in and out
Nov 20, 2008 | Pioneer GM-5100T Car Audio Amplifier
Wiring
The two seperate wire terminals on the sub are for dual voice coils which means. If You hook up the first terminal to the second terminal then run speaker wire from the second terminal to the amp.It should then increase the subs frequency response and sound better which also means it will be able to handle more bass. As to just having one voice coil hooked up. The two terminals is pretty much the bridge for the sub.
Dec 21, 2007 | Car Audio & Video
Rockford Fosgate Punch P550.2 150W x 2 Car Amplifier Car Audio Amplifier Logo
177 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
