Question about Viking VGSC306-4B Gas Kitchen Range
Various Problems 1. Broiler will not light. Ignighter is OK. Problem is lack of gas. 2. Right front burner is stuck.....can not turn up, or down, or off. We have to shut of the main valve in the back of the stove as a temp fix. 3. I would like to replace the complete set of burner & oven knobs. I can not find these parts anywhere. 4. Stove is propane gas. I believe it was pruchased and installed in 1999 +/-.
freetek
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
SOURCE: viking 4 burner gas stove
make sure that the electronic pilot gets hot by the flame of the burners, some times the gas air adjustmet is open to much and the flame will not get to the starter or electronic pilot, the electrode has a sensor that knows when the flame is on, if you see that the tip of the electrode is not been touch by the flame it will not stop, tiking. if that is not the problem replace the electrodes, or electronic pilot the same thing.
Posted on Dec 10, 2008
  • 42 Answers
SOURCE: Viking Gas Oven VGSO-166 flame too high
make sure the hood orifice is a #52. (orifice to bake burner)you can go to the local propane gas company and see if they have one they will sell you.
Posted on Dec 20, 2008
Kgt1962
  • 59 Answers
SOURCE: Oven barly heats up. It struggles to cook a pie.
Is the unit a self clean?
If not then the oven ignitors need to be replaced
Posted on Mar 08, 2009
Wolf broiler will not light
defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately
Feb 13, 2018 | Wolf Range Kitchen Ranges
Have xl44 GE Range /Oven--Oven and Broiler will not work. What do I replace?
Date: 8/2/2010
I have a GE XL44 oven. It's about ten years old. Oven would not turn on, so I replaced the igniter. The igniter has to light to "tell" the gas to come on. The part was $80 here in Oklahoma and it was super simple fix.
Pull the oven out of it's place and unplug. You can shut off the gas if your buidler placed a shut off valve.
1. The oven door pulls off without tools (I wish I knew this when I cleaned the oven last year) just open the door about three inches and pull toward your chin.
2. Remove the lower storage drawer.
3. Then remove the racks.
4. Remove oven floor. The oven floor comes off with two screws in back, then lift it about an inch from the rear and you can pull the front up, clearing the lip. This is a good time to clean the ten year old food off the oven floor.
5. You will see the aluminum burner. The lower ignighter is attached to the burner. The screws to the ignighter are at an angle, dont try to remove them with out taking the burner out. To remove the lower burner, get on your side and look way in the back of the lower drawer area. Remove the two screws at the very back where the oven drawer goes. You will also unplug the two (2) wires and the then the whole burner will lift up and come out, then you can remove the ignighter screws. Take the ignighter off and take it to a appliance repair store and they will sell you a new igniter. You can look on-line as well.
The new part does not have the connectors like the original, Just cut the old wires in half and pig tail them to the new part. The new part will come with ceramic wire nuts. This whole install takes about an hour, and will save you a service call. It can seem like a hard fix, but once you dig into it, it's pretty easy. Everything goes back together in reverse. This would be a good time to change the light bulb while you are at it.
These are the same type of ignighters that are on everything these days, hot water heaters, furnaces and they are the most likely to go out since they are used quite a bit.
Jul 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 04, 2010 | Amana ARGS7650SS Gas Kitchen Range
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Need instructions for starting my Frigidaire gas grill
ok turn on gas tank wait a couple seconds then turn on the burner to high and push egnighter till it goes click click and lights if no click click use a seperate lighter ..
May 26, 2009 | Frigidaire FD38NGDC Grill
Oven Not Working
see if your broiler works if it does replace the bootom ignighter even though it glowes does not mean its working right it has to pull a ceartain amount of amps for the safty valve to open if the broiler doesnt light then the safty valve needs replacing and reply for futher info
Aug 16, 2008 | Whirlpool GS460 Gas Kitchen Range
Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Jun 13, 2008 | Maytag MGR5751AD Gas Kitchen Range
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not working but burners are...
replace the glowbar just because it glowes doesnt mean its good the one you want to replace is the bottom one take the racks out and remove the bottom panel there are two screws remove the then under that will be a flame spreader remove that under that will be the burner bar and ignighter
May 22, 2008 | Frigidaire TGF317 Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
