Back to:
Tags:
Emerson EWC1303 13 in. TV/VCR Combo
Bt Sd-BT00U and Compaq r4000 laptop'
By mobileplanet
I already have an ipaq 3750 which is BT enabled and would like to use sd card in my laptop with the SD slot to let the two communicate. Does anyone have any tips for drivers etc as I have none???
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 30, 2006
Not Rated (0)
mobileplanet
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Does your machine even recognise the card? I would have thought it needed to be SDIO, although it is altogether possible that I am wrong. If it does, you could try to download WIDCOMM drivers (google WIDCOMM) and see if that helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Bt Sd-BT00U and Compaq r4000 laptop':
I don't want to Accept this solution
Can you Help with these TV Combos problems?
TV Combos
my tv comes on the only thing that it will do is samsung...
TV Combos
I need the code to program the remote control so that it...
i just got cable on friday it has always played pg 13 and...
I'm using a RCA Universal remote with this tv and was...
There is sound if I watch a video tape or use headphone...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
