Question about Pioneer TS-A6857 Coaxial Car Speaker
Connect positve and negative speaker wires
Which speaker wire pos n neg connect too on speaker one is slim and the other point is fat
  • tuhoequeen Sep 16, 2008
    Your information was spot on. Thanks for your help.
  • clover559 Feb 16, 2009
    wondering why the negative and positive are conected together on a 4 terminal speaker wire pioneer subwoofer?
  • 52 Answers
The slim terminal is the negative and the fat terminal is positive.
please rate, thanks
Posted on Sep 16, 2008
How can i hook these speaker to any radio using the neg and pos wires and witch wire is witch??
Answer to:How can i hook these speaker to any radio using the neg and pos wires and witch wire is witch??
Posted by Kelsey Doddridge on Oct 15, 2017.
With loudspeaker terminals facing you, negative or GND is left, positive or audio signal often marked with 'plus' symbol is right.
Otherwise briefly touch power from a 1.5 V battery, the one which moves the cone forward is the correct polarity.
Plus, if terminals are different sizes, follow Nick Elci's advice.
As for 'speakers to any radio', make sure your radio or amp does not overload and cook from too-low speaker impedance.
What this means is your radio may be rated at minimum 8 ohms or minimum 16 ohms per channel.
If you connect a 4 ohms speaker across this radio your radio's amplifier will probably overheat and fry.
I=V/R ohms law.
Also, never use a lower wattage speaker than what the amplifier is designed to output at maximum volume.
This damages loudspeaker, possibly tearing the diaphragm.
If you need to double the ohms from say 4 to 8 ohms, connect two identical 4 ohm speakers in series or SPK-A pos to SPK-B neg. Then outside terminals are neg and pos at 8 ohms and each one at half the power output.
Oct 15, 2017 | Car Audio & Video
How can I connect Bose 901 (speakers) to Sony STR-dh 520?
If you're using them in front then connect them via 2 wire (16 gauge or 14 guage) speaker wires to the back of the Sony unit. They're labeled left / right (as you would see speakers from the normal vantage point.) and front or rear. Make sure you get the pos/neg connections right. These are collored red (pos)/ Black (neg) on the sony and I believe they're red/black on the back of the bose speakers as well.
Feb 24, 2016 | Bose Audio Players & Recorders
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Mar 14, 2011 | Car Audio & Video
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
How do i properly connect the wires for a JVC SX-SW5th
Connect the speaker output of the reciever to the input of the speaker. Make sure you connect negative receiver output to negative speaker input and positive receiver output to positive speaker input.
Sep 15, 2009 | Audio Players & Recorders
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Subs dont work
To test speakers.A. Unplug speaker wires.
B. connect a 9volt battery to each speaker,touching one wire to the negative and the other to the positive breifly. The speaker should extend outward or inward, simulating the pumping of the cone. Depending on the polarity of the DC voltage hooked to the battery.
That's why it is important to wire the speakers correctly. Pos to Pos Neg to Neg.
You should know if the speakers or wired in series or parallele.
Google speaker wiring. Very informative.
Aug 12, 2009 | Harman Kardon HK695 Computer Speakers
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Speaker wire not colour coded
You can gently tap a nine-volt battery to the side of the wire pair that will be connect to the amplifier. When you've got the loudspeaker connected in proper phase, the speaker will push out, instead of pulling in.
Nov 26, 2008 | Audio Players & Recorders
Pioneer TS-A6857 Coaxial Car Speaker Logo
608 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
