Question about HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA)
HP Pavilion dv2224ea Digital/Analog TV-Tuner Card Not Working
I have inserted the TV card and run the installation on it but is not functioning.
Please can you help me out?
Thank you
Sylvester Evans
Name of TV Card:
Have u installed all drivers?
Posted on Oct 06, 2008
Tip
HP Express Card Digital / Analog not working
First thing I tried to do was to install the drivers that came into the CD didn't work, just using mydvd9 the import/aqcuire option I could have some noise signal, but couldn't find a way to select channels and hanged after a while. This is too trickier, I thought, it should be a way to used quickplay and other applications.
I couldn't get anything from HP site so investigating I found the following.
1) Had to upgrade quickplay to latest version (is pretty cool btw)
2) The card internally is a Hauppage and found that is actually the HVR1500 http://www.hauppauge.com/site/products/data_hvr1500.html.
Drivers + application can be downloaded at http://www.hauppauge.com/site/support/support_hvr1250.html
3) After upgrading quickplay and installing drivers and application from hauppage, Quick play had additionally an hp digital tv tuner entry, but here in canada there is no digital signal transmitted through antenna.
4) I have reinstalled manually the drivers that came in the CD, but from the c:\swsetup\HP Digital tv tuner folder
5) After this I had at quickplay a second source "Hp Analog Tv tuner" which allowed me to caputure the regular air signal and wintv worked as well
I'm sure that I did some redundant steps, but it worked and now can I have everything working (quickplay, wintv, digital, analog signals)
Hope this helps and btw I haev uploaded the manuals for thouse who can't get it, since HP doesn't have them in the website.
Cheers
Alejandro
on Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
Connecting and recording camera with s video output on 1221 tx
Your laptop has Tv Tuner card and if it takes TV input via cable , you get a S-Video / DVD cable to regular cable converter and use the laptop as a video recorder - if you are in US , any Radio Shack will be able to help you with the cables
May 17, 2009 | HP Pavilion dv6000z Notebook
Digital Transition
It's analog.  You need to purchase a digital receiver.  I personally have a USB external digital tuner running in Media Center 2005.  Search Ebay for "ATSC usb".  There's a lot of different options and most of them are pretty inexpensive.  To use a digital tuner in Media Center 2005, you have to leave the analog tuner / tuners in also.  You should still be able to use your current remote control with the new digital tuner.
Jan 25, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Tv tuner card in a hp m7434n
The white cable bundles (there are several) are for the front USB, Firewire, Analog Video and Audio cabling - none of what are required for your HDTV Tuner. The connections on the front of the HP Media Center allow for analog input (yellow, red and white RCA connectors) and some of the white wire bundles are for analog input (not on all HP PCs). Hope this helps...
Apex44
Jan 16, 2009 | HP Pavilion m7434n (ER901AA) PC Desktop
HP ExpressCard Pavilion Notebook
its definitely something you did.
theres a way to wipe system back to original pn hp screen.. F10.. that might fix..
if it dont. then bios is the issue.
Dec 20, 2007 | HP Expresscard TV Tuner For Windows Vista...
Hp express card digital/analog TV tuner
u may try this....i once have the same problem,around nov 2007 this was after vista updated some driver(keytouch,audio),my tuner stop working,so i go to the hp webpage and i downloaded the drivers for my laptop,after i reinstall the drivers my tv tuner start working again,and it is still working,got 13 digital channels working +22 analog all broadcast,i configure the vista update not to autoupdate but to tellme updates are available,then install the available updates except the ones that are drivers,u may try with the original drivers that are on the Hp/drivers folder.YMMV.
Nov 25, 2007 | HP Expresscard TV Tuner For Windows Vista...
HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA) Logo
284 people viewed this question
Top HP Televison & Video Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
