Question about Brother HL-2040 Laser Printer
Toner The toner light came on and stayed on, so I replaced the tonor cartridge. Even with the new cartridge, the light stays on and nothing will print.
  • 133 Answers
You could try two ways.
1) reinstall the software.
2) push "start" buttom for 1 min
Posted on May 23, 2009
How do i reset toshiba estudio 181 printer if the replace toner light keeps staying lid even when i put a new toner
Is nothing to reset, you must verify if the toner sensor is not dirt with toner. Best regards,
Dec 06, 2014 | Toshiba OEM ESTUDIO181 18 CPM/PPM...
Toner missing
Try removing and reseating the tonor cartridge.
Try using another (even used) tonor cartridge to test.
Some cleaning of the contacts and/or sensors may be required.
Apr 04, 2014 | Konica Minolta Magicolor 1650EN Full Color...
I have just put a new tonor cartridge in the printer but it still gives the message tonor life ended please replace cartridge
Hi
Just follow this steps.
Turnoff your printer for 2-5 mins and remove the toner cartridge, then put it back firmly. Then open your printer and try to print again. That will refresh the memory of your printer.
Jan 13, 2011 | Brother MFC-5840CN All-In-One InkJet...
The toner light stays on even after we have replaced the cartridge with a new one. Recently we replaced the drum and it was working ok for a short while and then the toner light stays on and the printer...
Here you got bud just copy and paste all this **** below into the http:// window at the top of your web box:
http://docs.google.com/viewer?a=v&q=cache:uNJvw-MWncQJ:www.oasis-imaging.com/images/pdf/cart_inst/Brother%2520TN360.pdf+Brother+TN360+by+OASis&hl=en&gl=us&pid=bl&srcid=ADGEESj4M8XLUS4yMo7hAf3nTuGGvKtaYS5_tHhGdh9WoDGinffOkVJPv8cp642xaSG5PkbrNrcUssyMY1ggc1xYlSZEu-JNeY4iVcXWD9O7MKza5_7CjyQyTPW7nnZeAQWm_d7f-MEE&sig=AHIEtbTarYNPKakKRnVcXg3pW_PBoi_4tA
You gotta reset the plastic piece at the end. Also, get you some black electric tape and tape the 2 circular clear plastic plugs on each end of the cartridge. The sneaky bastards at Brother shoot a laser through these clear plastic plugs and when the toner goes below these plugs that causes your printer to say your out of toner even though your not. Therefore if you tape over these clear plugs, then you can squeeze another 225 pages of pure printing bliss without needing a replacement.
Nov 08, 2010 | Brother HL-2040 Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Toner light and Status light stays on
well it may need to be completely reset or you could try seeing if it is jammed or stuck in some way
Sep 11, 2009 | Brother HL-5240 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Faded black print Printer says black tonor delivery problem
If you haven't already remove the toner cartridge and shake it, see if that helps. Have you replaced the cartridge ?? if not that would be my next step.
Jun 23, 2008 | Samsung CLP 300 Laser Printer
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Brother HL-2040 Laser Printer Logo
166 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
