Kenmore elite front load washer - wont drain and loud clicking sound from bottom
My kenmore elite front load washer (6 yrs old) wont drain and when i put the drain clycle on it starts to click loudly - is there an easy fix?
  • 5,911 Answers
Yes...sounds like you may have something lodged in the drain pump impeller. The following link explains how to check the drain pump on this washer for obstructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
It does not take much to damage the drain pump on this washer. If something has been lodged in the pump for any significant period of time, the pump may be damaged and required replacement. The may still run, but may not be pumping water as it should. You may experience an error code as well. On HE3 models, the error code is "F02" or "SUD". On HE5 models, I believe it is an "F21" error. Replacement pumps can be ordered on line at searspartsdirect.com.
If you find that you need to replace your pump, I have this additonal link, that provides step-by-step instructions:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Please read the note at the bottom of the link, as it IS possible for a pump to still run and not pump water. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 16, 2008
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
Water won't run into washer - clicking sound only front upper left like plastic gears running over each other
The fill valve is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore Washing Machines
Elite 73952 will not start
sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Mar 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
