Question about Refrigerators
Leaking fridge I heard a noise coming from the bottom of my fridge. It sounds like something is leaking.I looked and saw a small U-shaped copper tube leaking water. Do I need to shut down the fridge and call a service?
  • alitta Sep 17, 2008
    Thank you for your quick answer.
    It stopped alright and I thought everything was fine but this morning I had to find out that the fridge stopped working altogether?
  • 828 Answers
The U shaped copper tube is most likely the drain tube where the water frost defrost exits and drains into a drain pan to be evaporated. Even thing is fine, do not shut it down nor call for service. If you hear it again wait twenty minutes and it should stop. Then check it and I'm sure you will find it is O.K.
Have a nice day.
Posted on Sep 16, 2008
Where is the filter in the model HR6TFF342 is it in the freezer top or the fridge bottom.My fridge is leaking badly?
the leaking may not be due to ur filter?
Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Jan 18, 2017 | Refrigerators
Leaking water on floor
Freezer /fridge water/ice in fridge and or freezer
Apr 08, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
We an LG side by side refrigerator. There is water leaking from the bottom of the freezer door.
Mar 06, 2015 | LG LSC27931SB Side by Side Refrigerator
How do you stop a noises fridge and condensation in salad box
MAY BE DUE TO SAME CAUSE SEE THE FOLLOWING Freezer /fridge water/ice in fridge and or freezer, or leaks on floor
Oct 01, 2014 | Hotpoint RLAAV22K Larder Fridge Short
2007 vw rabbit check engine light slight noise under hood no oomph while driving
1t ck the fluids. Check the heat shields on the exhaust for secureness. Any exhaust leaks or vacuum leaks?
Oct 07, 2017 | Volkswagen Rabbit Cars & Trucks
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Blue fluid leak
There is no blue fluid in a refrigerator.
Something external or a add on is causing the blue fluid.
Mar 13, 2009 | Kenmore Refrigerators
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Banging Noise
If is sounds like a hollow metallic sound then the compressor is likely out of position os the unit has been mis-treated. if this is the case then the compressor will have to be changed (should be a 5 or 10 year wty) If is i a light sounding tap then it is likely to be some of the copper tubing is hitting the chassis. There is a metal or plastic cover that runs along the back lower part of the fridge, remove this and gently rock the fridge to see if you can re-create the noise.
Apr 25, 2007 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
