Scanning not picture perfect. In scanning a letter - the symbol on the letterhead did not print correctly nor did the signature part. The left margin also increased by 1 character. Bert
  • scrivem Sep 16, 2008
    I have tried adjusting the setting and scanned other documents invariably - portions are still not printed correctly.
    I am getting no where with the suggestions. Just cancel my charge to Visa. Thanks for your efforts.
    Bert
  • 6,487 Answers
This can be a problem with your scanner software, so the first thing that you can do here is try updating the software or better yet uninstall and reinstall the software so everything will be fresh and that should fix this problem....
Hope that helps...........
Posted on Sep 16, 2008
    Sergeant:
  • 264 Answers
There is a step you need to do to check that whether it is a software issue or the hardware issue.
First try to scan the document from the control panel using the Fax wizard. IF it comes fine that we have to deal with the software.
If not than i would also suggest you to use the scanner with another computer. Which will further eliminate the doubt between the software and hardware.
Most likely it seems to be a hardware issue
  • 928 Answers
It is possible that teh letterhead is too light that the scanner cannot see it any longer. can you try another document and see if the same problem occurs. If not then adjust the scanning settings.
How to write a letterhead to apply for an internship?
Normally a letterhead is a professionally printed blank sheet of paper with your name/address/logo/etc. pre-printed on the top. You could design your own letterhead using a word processing program to print as a header on your application letter. It seems pretty unusual to require a letterhead, especially for an internship. Perhaps they mean a letterhead from your university?
Aug 30, 2016 | Miscellaneous
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
I need instructions on how I can sign an email document that requires my usual signature via an email attachment on the computer screen. doe's it need scanning first i'm not sure how to go ab
Of course, you need to print and scan:-
1-Print the attached document !
2-Write your usual signature on the printed paper
3-Scan the paper by any scanner
Mar 18, 2012 | Computers & Internet
My HP Photosmart C4280 doesn't give correct colours when scanning
You can usually calibrate your printer. When you first get your printer you may have to run through tests. One of them is where you print out a sheet with multiple colours on it and you then scan it to calibrate the scanner.Scanning will rarely give a perfect representation of the actual photo or image but if you do calibrate it may solve your problems.
Jan 24, 2012 | HP Photosmart C4280 All-in-One InkJet...
Printing pdf's, margins are wrong and cut off on top and left.
Hi
Choose the correct paper size of your printer for scanning and printer because I believe you select the incorrect paper size and it cut the pdf scanned file.
Go to printer icon, right click mouse and choose printing preferences and choose the correct paper size. Then go to scanning properties and choose the correct paper size.
Mar 16, 2011 | HP LaserJet 1022 Printer
Slide scanning with Epson Perfection 2450
I don't know if this is truly a "solution" or not, but I get the same thing on my HP 4850 scans. After scanning, I just crop the pictures to remove the black borders. Can you do that?
Dec 08, 2008 | Epson Perfection 2450 Photo Flatbed...
Partial print
Are you sure you have the paper aligned correctly?
should be left top or center.
Do you have the correct sive paper (Letter instead of A4)?
What happens to the rest of the copy : cut off, blank, black?
Is the scanner light staying on when scanning the whole page or does it die out when it scans 3/4 of it? ( bad scan cable or board)
Jul 31, 2008 | Sharp AL 800 Copier
Random position of printing on page when using manual tray
delete this printer and reinstall printer driver from disc that came with printer then try printing
Jan 15, 2008 | HP LaserJet 2550L Printer
Letter G appear at the end of barcode
you have a "suffix" programmed into the barcode scanner. this is a common feature and allows for auditing (like a user signature) these can be removed, The code book should have pages of option programming barcodes, in which you should be able to find a section on programming prefixes and suffixes, there should be a control barcode which clears all suffixes. This should solve your problem
Sep 04, 2007 | Symbol LS2208-1AZU0300S Handheld
Computers & Internet Logo
David Payne
David Payne
