Question about Fujitsu Siemens AMILO D-7830 Notebook
Battery is not charging
I need to push the charger very hard into the laptop charging pin to make it charge and slight movement will disconnect the charging, and the laptop shut down with no charge.
  • Anonymous Oct 18, 2008
    umm well when i put my plug into the jack i get ready for it to chrge and it doesnt work i have the amilo pro could you help me?
  • Fujitsu Siemens Master
  • 4,338 Answers
The Ac connector on the system board is loose from it's connection. It needs to be resoldered. That entails opening up the laptop down to the System board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 13, 2008
I opened and started my laptop for first time on 26th April 2013, after initial settings and windows activation on same date,the battery was shown low by laptop,so I plugged charger. Now,as I am charging...
Are you using a 2-pin plug?
Usually when you use the 2 pin plug, there is no earthing/grounding available so the current passes through your body to the ground.
Try using the 3 pin plug. It should solve the problem.
In case it doesn't, it's better to get your laptop checked.
You can buy a 3-pin plug laptop charger at
http://memory4less.com/adapters-and-accessories
Mar 29, 2017 | ASUS Q200e Touchscreen Notebook
My acer aspire 7520-5185 will not turn on
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check.
The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Acer Aspire 7520
Jan 13, 2013 | Acer Aspire 7520-5185 Laptop
Battery not charging
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
DV7 did not working from fully gharged battery
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, which regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
Replacement HP Pavilion DV7 Smart AC Adapter 90Watt 19V 4.74A
Nov 25, 2012 | HP Pavilion dv7-1130us laptop
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
When my acer aspire 5734z laptop is plugged in the charger indicator flashes and the battery indicator shows blue.it stays at 0% and says plugged in,not charging.if i unplug the charger it shuts down. need...
Feb 11, 2011 | Computers & Internet
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
My nokia 5310, won't charge. I plug it into the wall, then it just stays there and nothing comes up with 'charging' like it used to before. I left it on charge overnight, but when I took it off charge the...
My Nokia 5310 also wouldn't charge; pocket lint had become trapped in the charging hole, and was packed down over time. I used a very thin straight-pin to gently scrape the lint out of the hole until I could see the gold-colored metal pad at the bottom (using a very bright flashlight and small dental mirror to direct the light). That took about 20 minutes. Now the charger plug slides all the way into the port and clicks into place. Tip: Be gentle, that center pin will break if you try to use something fat, like a safety-pin or a toothpick. -- John Dollison, Colorado.
Oct 29, 2009 | Nokia 5310 Cellular Phone
Dell laptop will not accapt ac power or charge
hi
please update the latest version of BIOS
if that does not work please contact the dell technical support they will replace the ac adaptor or
Sep 26, 2009 | Dell InspironTM 1501 Notebook
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
Fujitsu Siemens AMILO D-7830 Notebook Logo
244 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
