Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door circuit board replacement
I replaced my garage door circuit board that I was told to be the problem the door wouldn't work. It is a Genie 2020L. I was careful to reconnect all like before. The button to open the door now works but nothing happens when I push it. There is a blinking light when I press a button up by the circuit board, before nothing would light up. Please help!!! Thanks, Mickey
    Champion:
  • 244 Answers
Get instructions and program. I hate Genie
Posted on Jan 15, 2009
I have a Genie Pro Max - My light does not come on anymore when the garage door is activated. I have tried a variety of light bulbs to make sure that it is not the bulb. Can you help me?
Check the socket with an AC voltmeter and see if it is getting power when the door is activated, if not pull the opener apart and check the wiring to the bulb socket, if that is ok replace the circuit board.
Mar 21, 2017 | Genie Pro Building Materials
Learn button on genie pro max garage opener is not working . How can I programm new remote?
if the learn button is truly bad you have two options either replace the circuit board or buy an external receiver. It was me a would replace the opener with a Chamberlain/Craftsman or Liftmaster belt drive opener. The new genies aren't worth a damn. I've replaced about a dozen that were a year or less old because of defects this year.
Nov 07, 2016 | Genie Pro Building Materials
Entry pad quit working on my Genie Excelerator model #H8000D. Changed batteries.Can this be reprogramed or should I purchase a new one?
The relay on the "unit's" circuit board was causing my light to stay on. If I tapped the unit with a stick the vibration would be enough for the contacts in the relay to open allowing the light in the unit to go out. Call The Genie company; the H8000D Genie garage door opener has a lifetime warranty but only if you are the original owner of your home. If you are the original owner you'll need to have a receipt for proof of purchase. If you don't have the receipt then a copy of your HUD-1 form that you received at closing when you passed papers on your home will be accepted as proof of (original ownership of your home). I have had my Genie H8000D for 12+ years now and so far I have replaced the black indoor wall switch, the out door mounted remote control and both internal circuit boards. After removing both old boards I found that the solder on both ends of one "blueish in color" resistor had come loose from the board because he solder failed. I installed the new replacement boards Genie sent me and the unit works as is should. On the old board the resister didn't look bad so I soldered it back onto the board and I'll keep it for a back up.
Aug 25, 2013 | Genie Company Genie Garage Door Opener...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Garage door light will not turn on automatically when door is opened. Tried 't several new lights but that didn't work. Any ideas on troubleshooting?
This is either a light socket problem or a logic board issue. Unplug the unit and open the light cover. In the bottom of the socket there is a copper lead. Pull this up with needle nose plyers as the bulbs may not be making contact with the lead. Then try it out. If it does nothing either your socket is bad or the logic board is bad. You can test the socket with a circuit tester. If it is bad replace it, if it is good replace the logic board. You can get replacement parts at genie.com or overheaddoor.com. Thanks BB
Sep 14, 2010 | Genie Company IntelliCode GICT390-1BL...
My garage door opener a genie excelerator all of the sudden it will no longer reconize a remote, I have tried the reset button, and it is still not working. The light doesn't blink showing its receiving a...
The problem is that the logic board has gone bad. If you don't have a logic board 900 joules or higher on these units get some. You can get a replacement board at genie.com. Thanks BB
Aug 18, 2010 | Genie Company Genie Excelerator Down Limit...
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
How do you replace the battery in the genie garage door remote, its the small one
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
625 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
