Question about Microwave Ovens
I may have pressed cook time instead of timer (for 11 min).Now the display panel is off and hot. I have had the oven door open aand it still has not cooled. It's a GE model JEB1095
  • Microwave Ovens Master
  • 9,098 Answers
The magnetron probably over heated and the magnetron's thermal cutout (thermal fuse or TCO) blew.
Hopefully it protected the magnetron from destruction...
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 16, 2008
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
Sharp mdl R-1870 convection microwave runs for 1 min
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Jun 07, 2008 | Panasonic NN-S254BF Microwave Oven
Kenmore microhood model 665.62612200
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
It's also possible there may be a problem on the circuit board, which we repair nationwide.
Oct 22, 2007 | Kenmore 80809 Microwave Oven
Timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
