Question about HP Compaq Presario v3000z Notebook
Sleep mode troubleshoot
When my compaq presario V3618LA wakes up from sleep mode, instead of resuming windows, it restarts that whole system. it even sends an error message saying that windows wasn't shut down correctly, and offers me to open it in "safe mode". how can i fix that, and have a normal sleep mode, in which when it wakes up, it just resumes instead of restarting?
Diver sound instaletion
Posted on Sep 17, 2008
Computer will not wake up from sleep mode
Best way to restart it from wake up is remove the battery (if it is a laptop) or push the power button for at least 10 seconds (or more) until you can't see any lights at all or any sound from the hard drive. That is the only way you can restart the computer if it is not waking up from sleep mode.
Dec 14, 2017 | Computers & Internet
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
Pls help my compaq presario wont start up anymore.. after i put my laptop to sleep mode when i try to wake up or hit anybutton it doesnt wake up..then i press hold power button to force shut down,then i...
Hi
this may work for you
start up pressing the F8 key along with the power up key
then if it goes into repair optionstry the last known good configuration option
windows should then restart and try to go back to when all was good
hope this has helped you
if it has please let us know
so that we may be able to help others
many thanks
Jul 18, 2011 | Compaq Computers & Internet
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Laptop wont wake from sleep or hibernation
1. you will need to go into you BIOS settings for the mother board to disable the sleep mode.
2. You also have a " sleep mode" in your Windows environment.
Check how to in the "help and support" link at the start button or Windows Orb ( for Windows 7)
Apr 15, 2010 | HP Pavilion dv2000t Notebook
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Compaq SR5510f,ATI4550HD no display after resume from sleep mode
Have you tried a beefier power supply? Between the processor and the video card you have, you may be right at the minimum to run the machine. Ive had similar problems with machines in the past and they have all been resolved with more powerful power supplies. Step up to a 600 watt or higher supply and see how things go. Good luck.
Sep 19, 2009 | HP COMPAQ Presario SR5510F Athlon 64 X2...
When i put my computer to sleep, it will just wake itself up again shortley after, model is compaq presario SR5712F
Is it on any form of network ?
If so then there is a good chance you have "wake on lan" enabled or some other wake up application running.
Aug 09, 2009 | Compaq Presario SR5712F PC Desktop
Sleep and standby
Well... Sleep and Standby are not the same. While Sleep only turns off a few things, like display, WiFi, and HDD to save energy. Standby saves your session to the Hard Disk, the reason why the laptop seems unresponsible. This is the reason to uncheck Stanby if you want a fast wake-up.
Apr 16, 2009 | Compaq Presario Notebook
Compaq presario
Right-click your desktop and go to Properties (Note: Don't click an icon, just the background image of your desktop). Afterward, click the tab at the top of the new window labeled, "Screen Saver." Now at the bottom of the Window select, "Power." Now change the settings so that the system doesn't turn off the hard disks, enter standby mode, or hibernate. Afterward press OK, then Apply, then OK again.
Let me know if I can help you further, or if I need to describe any of the above instructions in more detail.
Mar 22, 2009 | HP Compaq Presario SR5610F Desktop PC
HP Compaq Presario v3000z Notebook Logo
440 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
