DTC P0741 TORQUE CONVERTER CLUTCH SOLENOID PERFORMANCE (SHIFT SOLENOID VALVE SL)
There are several possible causes for this code. Yes, it COULD be that there is damage inside the transmission that will require transmission removal and overhaul. However, I have fixed this code a number of times by simply replacing the shift SL solenoid which is mounted externally on the transmission housing.
I would recommend taking your car to a shop that specializes in transmission repair and get a second opinion.
Very possible the torque converter is bad, not the whole transmission
is the fluid full? smell burnt?
P0741....Torque Converter Clutch Circuit Performance or Stuck Off
P0507....Idle Control System RPM Higher Than Expected
that this dealer doesnt have the correct diagnostic software because their code is a generic code as well as the first one ,A GM dealer code would have been P1507 and this code doesnt exist in the GM list of codes ,i think they are both right and need attention but the gearbox code is a fault with the front clutch operating mechanism ,i would advise ripping teh autobox out and fitting a manual gearbox ,lot less hassle
