Question about Brother 1034D Mechanical Sewing Machine
Machine does not cut more than one layer at a time
Having difficulty with setting blades correctly. Material turns under but does not cut if more than 1 layer of material is sewn! Help
    Problem Solver:
  • 9 Answers
The upper blade most likely needs to be replaced or sharpened.
Posted on Dec 13, 2008
Why did it suddenly stop cutting?
Please provide the model of your machine.
Ok, it's a serger. Wondered why a sewing machine would be cutting unless it had the cut-n-sew accessory.
Most likely the blades are damaged or malfunctioning. Is the blade still moving when it is stitching? Is it just chomping away at the fabric but not cutting? If so, either or both blades need to be replaced. Consult your owner's manual. Usually only one blade can be installed without any technical knowledge. You can probably order the replacement blade and install it yourself. However, the other usually needs to be replaced by a knowledgeable technician because it requires some precision.
Has the blade stopped moving at all? If so, how long has it been since a thorough cleaning and oiling? Take it for service.
Mar 25, 2016 | Elna Sewing Machines
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
Do I have to have the cutting blades on the machine to serge material? Also, what's rolled hem and whats overlock?
No you do not need the cutting blade to serge but you shouldn't have to remove the blade it you should be able to push the knob at base of blade inward or pull it outward to turn blade downward out of the way.
TUTORIAL - How to do a rolled hem on a serger - StitchCraft
http://stitchcraftonline.com/blog/?p=42 - 71k - similar pages Aug 5, 2009 ... One of my favorite uses for my serger is to do rolled hems. A rolled hem is were the machine folds the fabric under a tiny bit and then stitches it.
Jan 05, 2015 | Sewing Machines
Can I stop my semco 750 overlocker cutting the material when I'm sewing
You should be able to disengage the cutting blade. Probably a button that you push in then rotate anti clockwise, this will turn the blade down under the machine therefore not cutting the fabric.
Good luck
Oct 04, 2014 | Sewing Machines
BLADES DON'T MEET ON OVERLOCKER
hi there
please see link to download user manual for JUKI MO-644D
http://www.juki.pl/support/HSM/Manuals/MO-654DE_manual_UK.pdf
and you must made upper and lower knife very close to cut material correctly.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Nov 22, 2013 | Juki MO-644D Mechanical Sewing Machine
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
My Bernette 203 will not cut the material or thread. I need to know the correct placement of the cutting knives.
First to see if the top blade is pressing against the lower blade when it goes past to make the cut.
You should be able to push the top blade to the right and have it spring back to the left. Do that to see if there is a small amount of presser on the lower blade.
Next, the cutting part of the top blade should drop just under the lower blade buy about 2 mil.
Also the lower blade should be level with the needle/stitch plate.
Blades also may need sharpened. The top one can be done with just about any sharpening tool but the botom is carbide so you will need a dimond wheel to sharpen it
Hope this helps
Apr 10, 2011 | Bernina Bernette 75
Trimed material keeps curling up into the
perhaps you are trying to cut off too much material, rather than having the material on the edge, so the blade just neatens it up. Also, the blade may be blunt
Jan 30, 2010 | Sewing Machines
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
Difficulty sewing quilt blocks
Try using a "walking foot" presser foot. It has feed dogs on the top to help all the layers go through evenly. A generic brand usually fits most all machines. :)
Jan 17, 2009 | Kenmore 15212 Mechanical Sewing Machine
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
98 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
