Thermaltake Symphony Mini water cooler making annoying rattling sounds!
I don't know what to do. My CPU cooler is making really annoying rattling sounds and its driving me crazy!!!!
Anyone have any ideas
Thanks
  • 1 more comment
  • simmsa Sep 16, 2008
    Sorry I forgot to mention it was a water cooler and pretty sure the noise is coming from a pump not a fan
  • Anonymous Nov 04, 2008
    i have the same type of problem, my new thermaltake water pump has started making a clicking sound, it appers to work fine but the sound it annoying and i am worried that it may be the end for my new system, there are no hose kinks, no leaks, no air in the circut, the pump just clicks constantly
  • BillyJoe3030 Apr 23, 2009
    Hello I have the same problem , I have to replace the pump but dunno how to do.
    No way to register to thermaltake forums, I found one post exactly describing my problem though:
    http://forum.thermaltake.com/viewtopic.p...
    I tried disassembling the system to reach to the dead pump so that I can pull it out and replace it with a new pump .
    Half way through there was absolutely no way to unscrew the pumps. I unscrewed the base of the system and reached the area where pumps are loacted. The problem is that both pumps are screwed to the body of the system wich is a big cast of Alu. There are screws there but no way to reach them at all unless I cut the body of the Symphony where the pumps are located.
    Any tips on how to dismantle the pumps off the Symphony Cooling kit are highly appreciated.
    At this point it seems that failure of a single pump in Symphony calls for the whole package to be replaced as there is no way to reach for the pumps.
    But as the member above posted he will be getting a replacement pump it clearly means there's a way to replace the pump, the question is how?
What I have done is called Thermaltake and they are sending me a new pump that can be replaced.
Hopefully that will solve my problem...
Posted on Nov 14, 2008
  • 67 Answers
Check the screws of the fan if it is seated properly. Then check your system unit if it is leveled on the ground. Or it could be dust or rust. You can try oiling up the fan.Open up the sticker of the fan and put little oil in it and put back the sticker. You may need to put extra tape as the oil may hinder the sticker from sticking back to the fan.
Posted on Sep 16, 2008
  • Kirk Philipson Chan Sep 16, 2008
    Ah, I'm not acquainted with the water cooling systems, but you could check the hose for any bent. Bent hoses may give extra load to the water pump. Just a guess.
Year old Symphony Winter evaporative cooler won't turn on, not even just the fan. Borrowed from friend, had to put on side to get in car.
Sounds like it's not getting power. Open it and check for an inline fuse or a reset button.Check the power cord for continuity first though, and make sure you're using a proven power outlet. It could be drawing too many amps, and tripping the circuit protection on that particular outlet.
Aug 21, 2013 | Symphony WINTER Evaporative Air Cooler
Where can i get a replacment one of these
Hi. And thanks for giving us this opportunity to help you. What you can do is go to newegg.com or tigerdirect.com to find cpu coolers and other various parts for your computer building needs. Hope this helps you.
Mar 26, 2011 | Thermaltake 208 Copper Water Block...
Overclocking heatsink!
I would suggest that you go for Thermaltake Duorb.
Even though its more expensive but it gives you a
perfect technology which keeps your CPU cooler
than your expectations.
Hope this helps you out.
Goodluck.
Feb 02, 2010 | Computers & Internet
Foxconn CPU fan making noise
It sounds like the fan bearing is shot, I'd recomend not using the computer until fan is replaced.
yes it is possible to replace the fan, i would recomend that you replace it with an aftermarket cooler. all you need is what kind of CPU you have, then find out what kind of socket it is, from there you can find the cooler you would like.
Jan 27, 2009 | Foxconn CPU Cooler Fan CPU Fan
Washing machine makes a loud rattling sound
Hi.k.
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Chopppy video / sound in parts of games
Try running the games on lower resolution and frame rate, see if that makes a diffrence.
Nov 25, 2008 | Video Game Consoles & Games
Water cooling noise
Could be air in the system which you would need to bleed out. Either that or a faulty pump.
Sep 24, 2008 | Thermaltake Symphony mini Water Cooling...
Any small CPU cooler could fit into this crow space computer?
That Thermaltake Cpu cooler you show is HUGE! Not surprised it won't fit! lol! It's 117mm Long x 102mm Wide x141mm Tall.
That's about 4-1/2 inches Long by 4 inches Wide by 5-1/2 inches Tall!
Suggestion for CPU cooler? Hmmmm, how about a ZEROtherm CF900? It's 100mm Long X 94mm Wide X 77mm Tall.
Here's the PDF file download for it's installation guide,
http://static.tigerdirect.com/pdf/Zerotherm_CF_Series_Cooler_Manual.pdf
Here's on place I found it on a quick search,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2882724&CatId=493
Speedfan is a software many people use to control CPU fan speed,
http://www.almico.com/speedfan.php
Perhaps you should try it. To change your fan speed in your BIOS Setup utility, you access BIOS Setup, and look in Advanced BIOS options. See if this option is there. I would use care, hence why I posted Speedfan instead.
Aug 01, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Water not moving
There is a Calcium buildup in the system. Try 'CLR Rust and Grim remover' Ray
Mar 06, 2007 | Thermaltake (CL-W0040) Water Cooling Kit
Intel p4 3.0ghz with 800fsb fan makes more noice
Hello Prask, Cooling the Intel's LGA775 CPU presents quite a challenge due to it's high operating temperatures, and while the ideal solution would be to use water, not all of us are ready to make the jump. The best solution I found for an easy replacement of the stock cooler is nMEDIAPC ICECONE Pure Copper CPU Cooler. It is an easier install than Thermaltake, and is just as quiet. You can find it here for the best price: http://www.directron.com/icecone.html Let us know if you need any additional assistance. Best regards, nightdiver
Aug 16, 2006 | Intel Pentium 4 630, 3.0 GHz...
Computers & Internet Logo
538 people viewed this question
David Payne
David Payne
