Question about Sony STR-DE525
STR-DE525 Blown fuse
Hi y'all ! I've used my sony DE525 amp in a party last week and I think I might have blowned one channel or the power supply.. Here is the story : all the 8 speakers of the place were plugged together to be played in mono with only 1 channel of the amp (I had no choice it was set like that I know its dumb but I couldnt do anything)... The amp was overheating and stopped 3 times in the night showing "protect" but since I had no other amp I continued playing, just dropped the volume a little until later in the night the amp totally stopped... The power supply fuse was burnt so I changed it and now when I plug it the fuse burns without even plugging the amp...
Im not really good with electronics I just want to know if I am able to fix it by myself...
Thanx a lot
  • Anonymous Jan 05, 2009
    My son has the same receiver and blew a couple fuses several months ago. He was told just to "pitch" the receiver, that it wasn't worth fixing. Hard for a dad to accept, as you can imagine. I just read your last comments to the fella about a similar problem with this same model receiver and sent your website address on to my son. I hope he will write you as it appears you would be able to help him/us resolve this problem. I was really happy to see your website--thanks, andkeep up the good work.
    President:
  • 624 Answers
Not very likely that you can fix it yourself with little electronic skills. You fried the channel you had it connected to. It will require the replacement of a lot of parts in the amplifer circuit. When a channel blows it has several transistors, several resistors, sometimes a couple of diodes and capacitors, and sometimes with the sony amplifers a pre-amp driver IC that will need to be replaced. You will require a multi-meter to determain which parts must be replaced, a soldering iron, some solder, and some solder wick to remove the solder from any bad components that must be replaced.
Any time you connect more than 1 speaker to a channel you risk over-heating that channel and shorting out some components. There are no amplifiers that are designed for more than 1 speaker per channel. I have repaired many sony recievers, including the one you have on several occasions, in the 18 years of working as an audio repair technician. With 2 speakers on the same channel you will draw double the amount of current thru the amp circuit than it was designed for. With 3 speakers on the same channel you will draw triple the amount of current and so on, and so on. I am really surprised that it played for more than just a few seconds with that many speakers on one channel. It must have been in really great shape to start with. I am sorry you did not know this before your party, it would have saved you some money.
Now the good news!
It should be able to be repaired. If all the speakers you had connected were really all on just one channel, you should have only one channel bad. This is a nice receiver as I am sure you must know, since you own it. It is worth getting repaired. As I have stated, I fix these for a living and I would expect the repair cost to be around $125 to $150 if it was taken to the service center that I work at. I can not be certain what another shop would charge, but this is a pretty good estimate considering I do not have it right in front of me to troubleshoot. Some shops are more honest than others, and there is always the chance that there may be more damage than what I would anticipate, or even less damage than I would expect resulting in a cheaper repair.
If you want to take a crack at fixing it yourself I would be happy to guide you thru it, but you would need the proper tools as I stated above.
I hope that you have found this information helpful, and if so, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free information and help.
Let me know if you want to try and fix it yourself, or if you have any other questions I can help you with.
Dave
Posted on Sep 16, 2008
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Sony STR-DE525 Left Rear channel not working
Most likely the amp for that channel is defective. If memory serves me correctly, there is a small amp chip mounted on the heatsink that is for both the left and right rear. I would change that first. It should have about 5-7 pins.
Dan
Nov 30, 2008 | Audio Players & Recorders
Sony STR-DE525 Protector mode
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Sep 24, 2008 | Sony STR-DE525
Fuses
have you tried to get fuses from maplin electronics.
Nov 22, 2007 | Sony STR-DE525
Str-db790
The output stage on one channel may be damaged or there may be a blown fuse for the side with no sound. If a fuse is blown, this is an indication of a fault condition.
Also, before assuming a failure, make sure that all the controls or setups are in their proper settings.
Jerry G.
Oct 12, 2007 | Sony STR-DB790 Receiver
Sound turns off for Sony STR-DE875 amp
If you do not here a click as soon as the power is turned on, (note you must be in a very quite environment no noise absolutely to hear this) then the amplifier has blown output transistors which are pushing DC current to the speakers.
Aug 31, 2007 | Sony STR-DE875 Receiver
Years of good service...now it keeps blowing fuse
The voltage of the fuse is not the issue. It sounds like you may have some blown internal transistors (probably in the output area). Time for a trip to the repair shop I'm afraid.
May 18, 2007 | Sony STR-DE525
Sony STR-DE525 Logo
311 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
