Question about NetGear WGR614 Wireless Router
My router doesn't have the wireless light on and i cant connect my laptap.
  • Anonymous Dec 20, 2008
    wireless light off, have to go directly through modem via an ethernet cable to get internet
  • Anonymous Dec 22, 2008
    I have a netgear router I have installed it and it is hooked to the internet and to my desktop. But able to connect to the internet on my labtop
Check if SSID broadcast is enabled in your router. You can do it by logging into your router's setup page. If this feature is enabled, you may try upgrading the firmware of your router. If this doesn't help, you can reset the router.
Posted on Sep 16, 2008
Hardware diagnostics
I have bought one wireless router from one of the dealer form found on
http://www.wirelessinternetrouters.co.uk. The router will have good wifi speed and connectivity. We are
Jan 30, 2014 | Lenovo Computers & Internet
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
My laptop recognizes the wireless dlink and works perfect, my wife's laptap, we used for the installation cd for setup and it recognizes the dlink, but the internet doesn,t work. Her laptap has windows...
not very clear but this may help.
1) make everthing is connect physically....make sure modem is connected to your router....then check that your router is connected to your laptop...everthing physically.
2) after you made sure everthing is connected. look underneath the router and look for and something that start with http://192.168.0.1
3) now go to your laptop and open up your web browser and type http://192.168.0.1 ....select "Admin" as username and dont type anything for password. then click on "log in"
4) then when you log in. click on "setup"which should be on top of the page....then select "internet" from left side of the page.
5) click on "setup wizard"
6) Click "Launch Internet Connection Setup Wizard"
7) click next
8) setup ur password
9)select your time zone...the click on next
10) then if your internet connection isnt detected you will need to select the company that provides you ur internet...if u dont find it then select "not listed or dont know"
11) also make sure you select "DHCP Connection (Dynamic IP Address" click next
12) click on " clone your pcs mac address"
13) u dont have to type in "host name"...click next
14) next now the wizrd should b complted and "connect"
15) now u shoudl have internet on any computer that is physically connected to the router with a ethernet cable.....but no wireless internet yet....now we are about to set it uo
1) click on "setup" on top of the page
2) click on "wireless settings"
3) click on the box next to "Enale Wireless"
4) type in a name in "wireless network name" for example "gary's wifi"
5) in "802.11 mode" i suggest picking "mixed cause you might have 802.11b in an old laptop and 802.11n in the newer laptops....with mized mode they will all be able to connect no matterif they are b,g, or n
6) den click "save settings" on top of the page...and NOW your wireless device should be able to connect to your wifi...BUT....remember we didnt put a password...so anybody around your house will be able to use it....if thats find with your then your done....if not then select wat type of security you want wep,wpa,wpa....and make a password..hopes this helps....let me know how it went.
Feb 25, 2011 | D-Link DIR-615 Wireless Router
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
I bought recently a lenovo laptop (G450) loaded with windows 7. I have wireless internet in my home that I use with my other windows xp laptop and it works fine. I never ever been able to connect to the...
have the same problem.  even after assigning a valid address statically to the network card and connecting with a wired connection, i cant even ping the router
Nov 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My router doesn't have the wireless light on and i cant connect my laptap. i have same problem
Reset it. It should have a tiny reset button on the back; you might need a needle or pen to press it. If this does not work, get a new router or get it replaced under warranty.
Dec 26, 2008 | NetGear WGR614 Wireless Router
Wireliss
Make sure your wireless is on, disable WEP on the router and see if you can connect, if you can try againwith WEP. If this fails try and use the hex key instead of the WEP password set up on the router. Also make sure that your router is doing DHCP over WEP or you won't be able to resolve web pages even if you are properly connected to the Internet.
Dec 09, 2008 | Computers & Internet
NetGear WGR614 Wireless Router Logo
132 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
