The security light is a visual indication that something in the car's antitheft system is failing. In most
GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you
put your key in the ignition, there begins a constant line of communication between your key's security
chip or transponder, to the ignition's lock cylinder, and then to the car's TDM (Theft Deterrent Module).
These 3 parts are in CONSTANT communication. If the key is in the ignition, then these parts are sending
signals to each other. The security light illuminates when that signal gets broken, even just for a second.
When the signal breaks, the car misinterperates this as an attempt at theft and goes into antitheft mode.
The car thinks its being stolen or hotwired because it is not getting that signal from YOUR specific key.
This is why the security light turns on and shuts down your vehicle. Remember too, the TDM controls the
security light. Sometimes you can have ALL the symptoms and no lights. This link explains it pretty well.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
