Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Hey, it's Emery again.
I tried your battery theory. One of my close friends has the same camera and I tried using her battery, but the camera still won't work. It won't show any signs of life.
  • 21 Answers
Well in this case you can better take it to a camera doc instead of u replacing the fuse.....because it might get more problems to ur camera.to be on a safer side just go to the doc n get it fixed.it must be a minute problem as far as i know.So thankx very much for the reply...good day...
Posted on Oct 01, 2008
  • 489 Answers
Hi
I dont know what your first thread said or what the answer was, but normally no-power has nothing to do with the battery, though trying another known good battery is the first step.
There is a small switch under the battery door beside the memory card slot. Is this switch damaged or missing? If so the camera will not turn on.
Your other most likely problem is the fuse, if its burned out it needs to be replaced. You will need to solder a new fuse in, it's really not extremely hard if you know how to solder and the fuse is cheap to buy new.
Good luck, let me know if you need more help.
Darntoothysam com
Posted on Sep 22, 2008
  • Thomas D.
    Thomas D. Oct 13, 2008
    Well in this case "DeviliveD", what's wrong with repairing a camera yourself if you know how to do it instead of overpaying somebody else to do it for you?
    I forgot to mention that you should check the switch inside the battery compartment beside the memory card slot... if that switch is damaged the camera will not turn on. Try pressing it down with a pencil and turning the camera on, does that work? Is the switch damaged, is it missing? Its a small black switch, without it.. no power.
    Don't EVER pay somebody $150 to fix a digital camera problem like this, you're getting RIPPED OFF. Even if you don't use my services, everybody needs to stop paying such high prices!
    It's like the brakes on your car. My local service station wants $375 to do my rear brakes on my truck, I can buy the parts myself for $125. Do they really need to charge me $250 labor to replace my brakes??
    Emery... Your camera either needs the fuse replaced or the entire PCB can be replaced, that will probably solve the no power problem. You can try buying a defective camera online and using the parts to make one good camera, or if you want a PCB I'm certain I can supply you with one.
    Pass the word around people... you don't have to pay hundreds of dollars to fix your camera even if some 'geek' (who actually knows nothing about repairing cameras) tells you so.
    Thomas D.; Darntoothysam com
I have a ge j1470s camera which is not switching on or charging
hello , some digital cameras go dead because of non use, low battery, if you have a/c adapter please use this and try, check the contacts of the battery and battery chamber if it corroded, use a mild emery paper and clean, bang the camera gently with flat of your hand, hope this helps
Mar 04, 2015 | GE J1470S Digital Camera
Tasco trail camera
Check the battery contacts for corrosion. If corroded, clean them with an emery board or sand paper and try the batteries again.
Oct 14, 2013 | Cameras
Camera keep on displating
OK try using some steel wool or emery paper (fine) on the terminals inside the batteryy compartement. I suspect there is some sort of corrosion or substance causing poor connection.
Hold the camera so no swarf gets retained in the battery compaertment. Wipe the area clean after rubbing contacts
please rate my help++++Thanks for using FIXYA
May 07, 2010 | Canon PowerShot A430 Digital Camera
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
Battery and card door slide is stuck closed
Hey marmof,
I would have it looked at by an authorized service center in your local area, and of course you can always bring it to a Geek Squad® precinct in a Best Buy™ store and have them look at it. I would not try forcing it open as this could cause additional damage to the camera.
Sincerely,
Allan
Go Ahead. Use Us.
May 07, 2008 | Canon PowerShot SX100 IS Digital Camera
DSC-W80 zoom extends, shutter opens, closes, zoom closes, 5x, won't work
Hey kbcinc,
I would try taking the battery out and waiting a minute and then reinserting the battery. Another option you have is to try and reinitialize the camera, but you would need access to the settings menu on the camera and it doesen't sound like you do. To initialize the camera go to main settings 1 and choose initialize. If this doesn't work I would bring it to an authorized service center to have it looked at.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 11, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
"Reinsert the Cassette"
If the warranty is no longer valid, try to identify what part of the camera is being scraped, then gently bend it back into place. There are a lot of thin metal shields inside the camera that could easily have been dented. I would strongly suggest a repair, as it is a very simple problem that can be easily fixed by moderately skilled hands.
Usually when I got that error message, I would take out the cassette, close it up, take off the battery, and smack it really hard a couple of times. It sounds odd, but it comes from a sony technician. It's the perfect temporary fix.
Jan 25, 2008 | Sony Handycam DCR-TRV260 Digital Camcorder
FinePix S9000
hi, This is actually a very good camera.Did you insert the batteries in reverse accidently?? this seems to be a problem with the switching circuit from battery and power adapter.. did you keep the camera with batteries for a long time with out use?? U can give it to the nearest service to get the circuit checked. all the best my friend.. sreejith
Jun 20, 2007 | Fuji FinePix S9000 Zoom Digital Camera
Samsung Digimax A7
Samsung customer support may help but If I understand you correctly you may have killed the camera
May 29, 2007 | Samsung Digimax A7 Digital Camera
Everytime I try to take a picture my cam turns off
That happens to me once in a while...Just when I feel like throwing in the towel, it starts working again! But I am actually having a problem right now: Even with fully charged batteries, the camera goes into "low battery" mode when I turn it on, and right now I can't download some really important pics...ARGGGHHHHHH!!!!!!
Nov 07, 2006 | Fuji FinePix A400 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
100 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
