Question about KitchenAid KAWS850L Top Load Washer
Washing maching My washing machine will not go into the spin cycle, it is 8 years old, it is making a very high pitched squeeling type noise.
  • jadadelaney Dec 07, 2008
    I have the same problem need help
  • tquinn5 May 11, 2010
    Joe, My machine is doing the same thing. problem is I already started taking machine apart thinking there was a belt. you have already answered my post on how do you replace belt. I a little learly about tackling this job. I pulled what I thought was a belt out. could see black fibers from the this. It looks like it may be a gasket from your instructions. Not sure where it came from. Should I put back together and then answer your questions about pumping out and agitating?
  • 76 Answers
Replace the motor have to remove the case and then the water pump, then the motor....the coupler in behind the motor
Posted on Jan 08, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
During clothes washer spin cyle makes a high pitch squeeling sound like letting air out of a balloon very slowly
Thanks for choosing FixYa and welcome. You need to check the motor drive and spin bearing. It may be the bearing. The drive motor controls the spinning, draining, and the agitation. Usually, when noise is associated with the spin cycle, it is either one. It is not an easy fix. Make sure to follow your manual. If not, you may want to call out a professional.
May 02, 2011 | Kenmore Washing Machines
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitch sound during rinse and spin cycle
makes loud squeel at end of spin cycle
Dec 27, 2007 | Washing Machines
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
KitchenAid KAWS850L Top Load Washer Logo
132 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
