Question about Olympus Cameras
How to set date and time on a olympus stylus epic zoom 170
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
epic zoom 170
See page 52
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 16, 2008
Olympus stylus 7030. No zoom function when using video setting?
The optical zoom will not work while recording video with sound. To use the optical zoom, turn the sound off. See pages 16 and 33 of this manual.
Jan 06, 2013 | Olympus Stylus 7030 Digital Camera
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
I need a manual for a Olympus Stylus Epic Zoom 80 (film type) camera.Thank you
http://butkus.org/chinon/olympus/olympus_stylus_epic_zoom_80/olympus_stylus_epic_zoom_80.htm
Aug 17, 2010 | Cameras
Date time stamp for olympus c-5000. How to turn
I had the same problem. I wanted to set my Olympus C5000 Zoom to automatically date stamp photos. After going through the entire manual, I had to call Olympus directly. They told me that none of their cameras have an internal date stamp feature. They said that the date stamp lowers the quality of the picture, so they choose not to have the feature available. However, you can manually add the date and time stamp through the software that comes with the camera, just before you print the pictures. Hope that helps...
if you need help with that manual go to http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/ and get our off the list.
It is on there!!! about the middle of the page.
Sep 10, 2009 | Olympus Camedia C-5000 Zoom Digital Camera
Date/time function
Actually, it was easy. My fault. I didn't realize I could keep scrolling through my "set-up" option - from "menu" to the date/time icon. Once I found that, I just had to work my way through it. The only thing is, it's set up as a 24 hour clock, and I would prefer it as a 12 hour AM/PM. Haven't figured out how to change that yet, but it's not serious. At least the date will be correct now.
Dec 28, 2008 | Olympus FE-170 Digital Camera
Problem
You haven't specified what camera model you have, but I suspect the problem could be due to the white balance setting on the camera. Read your owners manual and check the section on adjusting the white balance. If you have it set for something opposite to the actual ambient lighting condition (ie the setting is for incandescent light bulbs, and you are shooting outdoors in sunlight, for example), then it can really throw the colour spectrum off.
Nov 23, 2008 | Olympus Stylus Epic Zoom 170 35mm Point...
Olympus D-535 Time Stamp on Pictures
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order or print reservation that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Oct 23, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus FE-170
The FE-170 is not equipt with microphone for sound with video. Sorry. The only fix is to buy a different camera.Some with sound are:Olympus FE-190, FE-230, most Stylus brands and newer FE model cameras.
May 29, 2008 | Olympus FE-170 Digital Camera
Olympus Stylus 760 problem
I just called technical support and they told me the camera has an internal problem. You have to call them if your camera is still under warranty and send it to a repair center.
Apr 29, 2008 | Olympus FE-170 Digital Camera
Date and time change
First you press the button called "MODE" and, without releasing it, press the "SET" button.
Then, the year will start to blink.
Set the year with the "SET" button. Once you finish setting the year, press the "MODE" button to change to the month.
Then, the same way with the month, day, hour, minutes.
After minutes, the display will stop blinking.
YOUR SET!
Dec 08, 2007 | Olympus Stylus Zoom 140 Deluxe 35mm Point...
Cameras Logo
103 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
