Auto-tune isse Hello, I have a 17 inch Soyo monitor, model # VT17N71 On boot up, the sceen goes to the right of the monitor, I have to manual press the auto tune button to have it correct itself, if I leave the computer for like 10 minutes then the screen will go back to the right side again untill i press the auto tune button again...any suggestions?
  • 2 more comments
  • Ansat Sep 17, 2008
    looks like setting the refresh rate to max did the trick, or atleast appears to have fixed it....
    Thanks for the help.
    Setting the refresh rate to max appeared to have done the trick, thanks!
    setting the refresh rate did the trick...thanks
    AH! shuddap!
  • 1,019 Answers
you could try adjusting the screen resolution in My Computer/Control Panel/Display this may help.
Also have a look to see if the Adaptor, is set for optimal refresh rate.
Mike @ Compurepair.
Posted on Sep 16, 2008
Too easy, one would of thought he would of tried adjusting this already - I guess some would rather ask than try. :) se'la'vie
Posted on Sep 17, 2008
I have a Soyo 26" and no manual. The problem I am having is that the image does not fill the sceen, does any one have a solution?
check its remote there would be a zoom button on it. with wish you can zoom the image. every time you press that button the screen will change like X2,X3,X1/2 etc. Select the normal mode.
Nov 11, 2015 | Soyo 26 in. LCD TV
I have a 20 inch monitor that the screen is off center.The picture is blank 2 inches on the right and part of the left is missing.
I am guess your have a CRT monitor. There should be a menu button or knob on the monitor. Press it and a menu should come up that will allow you to adjust the position and size of the screen display.
If you have an LCD monitor, the resolution of your desktop is smaller than the screens native resolution. There sould be a button marked "auto" press it and it should correct it. If not, find the desktop screen resolution section in your operating system (control panel) and make sure it is set correctly. If it is wide screen, set it to 16:9 and then set it to whatever has the word "Native resolution" written beside it.
May 14, 2011 | Soyo Computers & Internet
My Soyo 17" TFT monitor comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after about one second each...
Thank you for your query
Your monitors inverter has burnt out and will need your monitor replacing
I did not even ask for a bid for this as i dont think you should have to pay for a easy solution
Sep 24, 2010 | Soyo DYLM24D6 LCD Monitor
I need drivers for my Soyo MONITOR, DYLM017B Model:VT17n71.. Windows 7 is tellin me its out of range
I've spent a bit of time researching this problem for you and have come up with the following, hope it helps.
SOYO has quoted "All SOYO monitors are Plug and Play monitors. They do not require drivers to work". Recently SOYO went bankrupt so their website is now unavailable for any form of support.
What i would recommend to you would be to temporarily connect a CRT monitor (one of those big bulky monitors) to your computer, as these have a larger resolution and refresh rate capability.
Once you can see Windows 7, change the display settings to the minimum settings for your monitor (as a safe bet i'd set them to 800x600, 60Hz until you connect the LCD). Then connect your flat panel monitor again and set the display settings to an optimal level for you.
Again, i very much doubt that you will need a driver for this brand of monitor, and will be hard pressed to find one.
All the best, and i wish you luck :)
May 10, 2010 | Soyo DYLM1788 Monitor
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
Just a general suggestion.
Are the graphics drivers loaded.
(Assuming you are using Windows) what happens when you rightclick on the desktop screen and you click on the Settings Tab
Jan 06, 2010 | Soyo Computers & Internet
Soyo 17'' Monitor (DYLM017A)(VT17N71), identity of fuse.
Orange color of the ring means number 3. Part of marking also contains "3A" so I'm pretty much sure it is 3 Amps rated fuse. But before replacing it measure the resistance on the PCB where that fuse was blown, between common mask (usually metalized mounting holes are connected to it) and the second pad of that fuse. How much is there? If you measure less than 12/3=4 Ohm the new fuse will blow again and you need to find what is shorting the power supply.
Sep 12, 2009 | Computers & Internet
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Computers & Internet Logo
525 people viewed this question
David Payne
David Payne
