Question about Panasonic NN-C980 Convection/Microwave Oven
Operates for 3 seconds on microwave then stops
We inherited a Panasonic Model NN-C980 microwave/convection which looks brand new BUT it will only cook on microwave for 3 seconds - then stops. Its previous owner said it worked great at the repair shop but went back to the 3 second regeim when he plugged it in at home. Do you have any suggestions? Thanks, John Paxton Serial # 6B40100216
  • Anonymous Sep 16, 2008
    I have the same problem.
  • Panasonic Master
  • 9,098 Answers
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 16, 2008
When started,light& turntable operate normally,but no heating by microwave. Transformer normally sounds smooth,but now makes rattle or vibrating noise,like something is loose.
Check the door safety intertlock micro switch for proper behavior. If it is faulty, the oven will think the door is open and will not turn on the magnatron.
Sep 22, 2010 | Panasonic NN-C980 Convection/Microwave...
Pizza does not get hot when switched on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Microwave stopped working
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Oct 16, 2009 | Panasonic NN-C980 Convection/Microwave...
Microwave stuck in demo mode
try unplugging it for 10 minutes. Otherwise, try looking at the instructions:
service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
Sep 14, 2009 | Panasonic NN-C980 Convection/Microwave...
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
May 28, 2008 | Panasonic NN-S262SF Microwave Oven
Microwave oven problem
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www.panasonic.co.in/
Oct 16, 2007 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-C980 Convection/Microwave Oven Logo
476 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
