No sound Toshiba M45-269 laptop
I suddenly lost all sound on my M45-S269 laptop. I don't have sound on startup, in media players (windows media player, real, or any others). I get an exclamation mark under sound in device manager and the error no sound card found. I have dowloaded new drivers and get same message.
    Scholar:
  • 135 Answers
Seems that the drivers for your sound card is not installed. Just update the sound driver. Where did you purchase the product? Where did you download the driver? You could have download a driver for a different OS.
If the excalation mark on your device manager is gone, that should fix the isse.
Hope this helps.
Posted on Sep 16, 2008
Sound quality Toshiba laptop
Have you tried another media player? Have you done ALL your Windows and Toshiba updates? Has there been ANY damage?
May 06, 2013 | Toshiba Satellite Computers & Internet
Fix it diagram owners manual for toshiba satilitte M45-s269
Try running check disk.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.------------------------------------------------------
If check disk does not solve the problem then you'll have to reinstall your operating system.
Apr 02, 2012 | Toshiba Satellite M45 PC Notebook
Cant see my movie but here sound
If you're using windows media player its probably because you don't have the right codecs.
Try opening the movie with vlc player or MPC-HC.http://www.videolan.org/vlc/
http://mpc-hc.sourceforge.net/
Dec 07, 2011 | Toshiba Satellite L455D-S5976 Notebook
I have suddenly lost the sound on my windows media player I may have touched something I dont know it has been OK all this time, it plays but there is no sound please help
It appears that accidently you have clicked on the speaker icon in windows media player which has muted the sound. Please click again on the speaker icon. The sound will come back again. If it does not then check the volume settings on the task bar. This ma have been muted. Click on it and see the volume settings. The slider should not be absolutely down. Slide it up. The sound will come back again.
Jul 17, 2011 | Computers & Internet
No display on screen, but i have sound
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 21, 2009 | Toshiba Satellite M45-S269 (PSM42U016006)...
Play dvd nothing - play s/d card (video) sound but no picture.
You need to update the dvd softwear. Check the default settings for playback of media,if it is set to windows media it won't work if you hav'nt installed the correct updates. Choose the Toshiba dvd player as the default player and it should work. If you prefer windows media then you can get the updated codecs from ' free-codecs.com ' Easier still,try uninstalling your windows media player and installing windows media 11, this will usually resolve the problem.
Oct 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Sound, headphone port, pointing device & 2 of 3 usb inop
maybe the laptop you bought was made or design only for windows vista, in that case you have to download all the drivers for windows xp if it is available in the internet.
Apr 10, 2008 | Toshiba Satellite M45-S2692 Notebook
Inbuilt Speaker not working
Dear Biswaranjan.
the volume control on media player before that there is one button for speaker click on it and sound will come from media player. I think you have muted on media player.
Feb 26, 2008 | Computers & Internet
Psp-lost music when i hooked to wimdows media player
there in a file some where. rerun media manager and pay close attention to where the files are kept
Dec 29, 2007 | Toshiba Satellite P30 Notebook
Computers & Internet Logo
136 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
