Question about Hotpoint RGB745 Gas Kitchen Range
Digital clock and oven won't turn on, doesn't even light up. Yet the stove top with the ignitors works.
  • courtnaful May 11, 2010
    What does this mean, "a clock problem"? What do I do?
  • 943 Answers
Hi ifthe digital clock is not lighting up you have a clock problem
Posted on Sep 16, 2008
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
I have a gas stove/oven the ignitors to the top clicks but doesn't spark and the oven doesn't work at all?maytag performance
Number 13 and 22 is the parts I suspect.
13 is the ignitor which even if it glows could be weak, It must pull at least 3.5 amps to open the gas safety valve. The spark module(number 22) could also be weak and not putting out enough juice to light them burners. Seen it.
Sep 18, 2011 | Maytag MGS5770 Gas Kitchen Range
I have a Kenmore Range Model 911.7378710. The oven won't turn on. The top burners are working. When I turn the oven knob, there's no sound, It's an old stove and I can't find if even...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 24, 2011 | Kenmore Kitchen Ranges
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
My oven does not heat up. Everything else on the stove works (top burners, clock, timer, ect.) When you turn the oven dial, it even clicks as if it were to start the oven.
heatman101
Jan 10, 2011 | GE JGRP17 Gas Single Oven
Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
May 14, 2010 | Ovens
The oven will not turn on, it has not worked since a power outage. it is a gas oven the burners on the stove top work, but the oven will not.
its either the eoc ( clock ) of the ignitor . see if ignitor is glowing and how bright / if orange replace . if its not going it may be clock . mm
Dec 12, 2009 | Dishwashers
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
139 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
