Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Blubber have changed spark plugs and wires bike still blubbers at slow speed will run fine when pulling got to be elec doesnt it?
  • 216 Answers
It doesnt...could be a fuel problem, or even a vacuum leak. You dont say what year bike, but if its carberated, I'd check visually for a good gas stream/ check for **** in the tank...service the air cleaner as well. Check the fuel air mix and set the RPM's to 950-1000 at idle. If that doesnt do it, check the condition of all your fuel and vacuum hoses
Posted on Sep 16, 2008
My bike keeps backfireing
bike is 10yrs--carbs are varnished and dirty-clean the high speed jets-u need a clymer manual
Oct 25, 2011 | 2002 Honda VT 1100 C2 Shadow Sabre
My 2006 Freestar was hesitating (or sort of jumping) at around 70 km/h and then yesterday was doing the same when I got tried to excellerate at about 100 km/h (on the highway). By the time I got home it...
Sounds a lot like the fuel pump for a starter. When it acts up does the vehicle jerk or buck before picking up speed? I have also had the experience with just one spark plug wire or plug bad. You can check this by pulling each wire one at a time while engine is running. If the motor slows that plug and wire are fine. If no change in rpm check the plug and wire.
Jul 27, 2017 | 2006 Ford Freestar
After about 3 hrs.bike beginns to blubber on low end.after bike cools off it runs fine.
blubber when hot usually means rich mixture. Is the air filter getting dirty?
May 31, 2010 | 2003 Suzuki RM 250
Cuts out at medium to high throttle-runs decent @ slow speed-idle seems to high
It could be the spark plugs. Check the color of the spark. It should be blue not orange. If it's orange change the plugs.
Sep 20, 2009 | kawasaki Quad Bikes
03 CRF450 R push starts and runs, will not kick start.
the bike might have to much oil in the bike so when you try to kickstart it, it sends oil to the piston and soaks the spark plug in oil. But when you push start it the spark plug is going alot so it catches, just kicking it doesnt give enough spark tho. my bike doesnt the same and then somtimes i have to take the spark plug out and clean it with a wire brush then usually its fine. Or you could have the wrong oil in the bike, i would read the maunal to find the perfered oil. hope this helps
Sep 07, 2009 | 2003 Honda CRF 450 R
I changed spark plugs and car still misfires and loses power when frist taking off and when going up hill it's a 97 mercury sable. what else could i do?
i bet your spark plug wires are bad. Arching is occuring (when the spark doesnt get to the plug) Probably because of old cracked wires
Jul 28, 2009 | 1997 Mercury Sable
SPUTTERING WHEN HOLDING 50-60 MPH
Since it ran fine before you "fixed" it, go back over the things you changed. Put the old spark plugs back in it. Double check all spark plug wires and ignition connections. Put the bike in a dark area and run it at night, can you see any arcing anywhere?
Jul 01, 2009 | 2004 Honda VT 1100 C Shadow Spirit
Elec. fuel injection / harley davidson
Sounds like a knackered / flat battery. Check the battery, look at the terminals and make sure the wires to the battery are connected properly. If the battery is good then check your charging circuit.
Apr 27, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
94 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
