Question about Dryers
How do u stop a dryer from squeaking? - Dryers
  • john gagnon
    john gagnon May 11, 2010
    hi thanks for the question what make is this dryer
  • 943 Answers
Yes thoseparts would solve this problem
Posted on Sep 16, 2008
At the start of the drying cycle the dryer would squeak for a few minutes as it heated up the squeaking would stop ;now the dryer will not turn on, only hums whn the start button is pushed..HELP!!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 30, 2011 | Dryers
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Jan 02, 2011 | Dryers
When ever the dryer is running it make a horrible squeaking sound until the load is done. How do i stop it from squeaking?
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 20, 2010 | Dryers
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
417.83142201 just replaced felt pads, upper and
try to lube the rollers on the back wall, where the drum mounts , sometimes the wheel bearings tend to make noise specially when dryer is overloaded and hot
Feb 05, 2010 | Kenmore 83142 Electric Dryer
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
Our dryer is making this loud squeak how do i get it to stop
ON THE REAR OF THE DRYER YOU WILL SEE THE REAR END OF THE DRUM SHAFT TRY SOME WD40 AND SPRAY A LITTLE AND SEE IF THIS STOPS THE SQUEAK IF IT DOES YOU WILL NEED TO REPLACE THE BUSHING FOR THE REAR SHAFT
Aug 08, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Jul 31, 2008 | Dryers
Dryers Logo
168 people viewed this question
Top Dryers Experts
