Question about Logitech Quickcam Chat Webcam
Problem receiving good video and sound using skype. Picture comes through choppy, fuzzy and very grainy. I am told that my video and sound that i send out is great but I'm not receiving it the same.
  • sgfrance Sep 15, 2008
    HI !
    I have a yellow 2 cm wide vertical bar on my screen when I'm using Skype.
    Apparently, the problem is only on my side.
    Otherwise the webcam works fine ... but the bar is annoying.
    Thanks for help.
    Sergio
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 13, 2009
When i turn the TV to vid1 is has a crisp clear picture but when i turn hit the satellite button it goes to chanel 3 and is fuzzy (grainy looking). Any suggestions? I cant leave it on the vid1 channel...
Get a surround sound system. Run the video to av1, and then the red, and white audio cables to your surround sound aux. You will get the clean picture and great sound.
May 05, 2010 | RCA HD52W59 HDTV Projection Television
Logitech quickcam gi ves me fuzzy picture when i
A bit of fuzziness is expected especially when you move. How fuzzy depends on speed of your computer and the capture ability of the camera. I have quickcam that is 1.3 megapixel. Stationary objects are pretty clear, but all motion is fuzzy and distorted. Move slowly to help minimize the distortion. When using instant messaging or Skype, set camera to a smaller image size for faster compression and transfer.
Bret
www.1-2-1computerservices.com
Oct 06, 2009 | Logitech QuickCam Messenger Web Camera
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a microsoft life cam vx 5000. During video call the video is extremely grainy or "boxy"....audio is choppy....constant flickering in the picture. Cannot go a few seconds without the picture...
Sounds like a network problem. Is your internet connection intermittent? Or maybe a bandwidth problem.
Try using a cabled connection in case you are using wireless.
Close all other applications that are using the internet connection.
Jul 27, 2009 | Office Equipment & Supplies
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
I am hooking up a Panasonic - Flat-Panel Plasma HDTV TH-50PX80U to a receiver. The sound is good. The problem is the video. It's in black and white and sort of grainy picture
check your connections. it sounds ( looks ) like you may have connected the video cables incorrectly. the inputs and outputs are color coded, even if the cables you are using are not you can still use them.
Dec 03, 2008 | Panasonic 50" 720p Flat-Panel Plasma HDTV
Skype video and chat
What are the specs of the computer you're using? Skype need a pretty good computer and a good bit of memory RAM to operate on a computer really well. Older computers just won't run Skype well.
disaksen
Sep 15, 2008 | Logitech Quickcam Chat Webcam
Logitec quickcam problems
Seems not a problem of your camera as the image it records of you is transmitted clearly to the folks you call. Maybe those people should get the same camera you use.
Or it their/your internet connection upload/download speed
Or it is skype - i use skype, but some of my friends move to MSN as they say it supports better quality experience of video chats
Sep 14, 2008 | Logitech Quickcam Chat Webcam
I have tried adjusting all adjustments (contrast,tone,color etc) but the picture still looks grainy and consequentally fuzzy. I also tried putting it on Auto adjust to no avail
two things come to me. check your cable connection going to tv . and wall. if all that checks out and you now you cable is good .you could have a bad tuner in your tv .cost of fix is around 95.00 dollars for a repair shop to do.
good luck I hope this helps thanks doctor video leadingedgeelectronics since 1987
May 04, 2008 | Televison & Video
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech Quickcam Chat Webcam Logo
146 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
