Question about Kenmore 63942 Dryer
Dryer belt route
  • Kenmore Master
  • 19,396 Answers
Click on the picture below:
Click on picture
Here you see how to access the belt.click
Posted on Sep 15, 2008
GE DRYER MODEL dvlr223egoww.BOUGHT NEW BELT SEEMS A LITTLE BIG.BELT WONT TUMBLE.
Hi maddy21350...
Make sure you have routed your belt correctly, if it is not properly routed then it can cause the problem you are talking about.
Go to the following webpage and see a picture of how to route your belt properly.
If you have it correctly routed the you got the wrong belt.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Aug 18, 2011 | GE DVLR223 Dryers
My whirlpool dryer is making a very loud noise when on< sounds like it is destroying everything in the dryer. i checked the dryer hose all clear of debris!!
you will need to open up the dryer, make note of the belt routing and remove the drum as the drum rollers/glides are bad, here is a website. Hope this helped Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
belt routing:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 22, 2011 | Dryers
Can't get belt on dryer properly
The routing for the belt should be on a diagram somewhere inside the dryer. It sounds like the belt is not properly routed around the idler/tensioner pulley -- this is a very tricky routing -- without a diagram, it's a bunch of trial and error. Can you find the routing diagram?
Apr 22, 2009 | Dryers
Dryer belt routing
it should loop aroud the drum then form a small loop to go around the motor . you may have to push the tensioner forward to get the belt on the motor. if not go to the parts store and they can show you
Apr 08, 2009 | Dryers
New Belt and pully-wont activate swith to start dryer
The main cause of this is improper bely routing. Click here and verify that it was routed properly.
SG
Apr 07, 2009 | GE Dryers
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryer belt routing
the best way i can tell you is open the back put the belt on the motor then visually pull the tension pulley back and put the belt on the tension back on the belt. if you are changing the belt you must touch the spring.let me know how it goes.
Nov 11, 2008 | Dryers
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Sep 18, 2008 | Maytag Dryers
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
