Singlle long beep on booting up my Biostar M7NCDPro motherboard with nothing on screen
  • 40 Answers
If you get one continuous beep (Long and Non-Stop)
This could happen if:
1. The Power supply is damaged or bad.
2. The BIOS is corrupted. Try resetting the CMOS using JCMOS1 jumper on the motherboard or remove the battery from the motherboard for 20 minutes. At this point the first thing to try is a different Power Supply to see if the result is better. If the same problem happens with the new power supply, you may need to send the BIOS Chip to local dealer for reprogramming.
If you get one long High Pitched tone that does not stop until you disconnect the power supply:
1. Check if the CPU fan is connected to the JCFAN1 connector.
2. The CPU might be overheated. Change the CPU FAN or check if the CPU fan has proper contact with the CPU. Refer to your manual for CPU installation.
3. Clear CMOS battery (JCMOS1), be sure to set JCMOS1 back to 1-2 position. (See Quick start guide/ user manual for more info on how to clear the CMOS)
4. Make sure the power supply you have on your system supports the M/B specification. Example. If you have a P4 M/B, you need to use an ATX v2.03 specification power supply. (power supply that has an extra 4-pin square connector)
Posted on Sep 15, 2008
Motherboard Error Code 62
first replace your ram,if problem occur,then check your c.p.u
Jan 26, 2014 | Biostar Computers & Internet
CPU freezes on boot up
try reset CMOS.or re-wiring the electrical wires,make sure they are seated tight.
Jul 24, 2013 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Checksum error,boot failure on start up..wont continue..some beeping sound
make sure the compters ram modules and Cmos are securely seated with no dust in the sockets If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Aug 18, 2011 | Biostar MCP6P-M2 Motherboard - v6.0,...
Hi-low beeps at boot. System won't even get to BIOS.
That is probably your ram. If you have more then 1 stick remove them and install one at a time in slot 1. If that isn't it you need to count the beep and duration of the beeps. I can then look up the codes. I will also need to know your bios manufacture.
Jul 09, 2009 | Biostar M7VIT Motherboard
Pc used to work fine but now won't boot, post or beep. No sounds at all, just a black screen and monitor lamp stays on orange!
Check the mains power supply cable. Try to Connect with another cable. Or, the SMPS power supply unit may be at fault.
Jun 24, 2009 | Biostar P4VMA-M Motherboard
PC powers on but nothing on screen, no beeps
yo, try to clean the gold contact of your video card and RAM by an eraser... then put it back to it's position in the motherboard make sure that it is connected firmly...
Jun 10, 2009 | Biostar K8M800-M7A Motherboard
Beeps when boots
Most likely a problem with your RAM.  Either it has gone bad or has been disconnected from the motherboard.
Apr 27, 2009 | Biostar U8668D (802700113338) Motherboard
Stops booting
Did you remove the components that you upgraded, and try adding them back one by one?
Will it give you a POST screen?
Does it Beep at boot time? If it is noisy try moving it to another room.
Describe the original components and then the ones that you upgraded in detail. This will allow us to better troubleshoot the problem.
Dec 02, 2007 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Computers & Internet Logo
410 people viewed this question
David Payne
David Payne
