Question about Konica Office Equipment & Supplies
I keep getting "dirty copies" from both the scanner and top-loading portion on my Bizhub 7255. I have tried cleaning the glass but the problem persist. I did notice a pool of ink below the toner door, but this did not happen until quite recent. Please help!
  • Konica Master
  • 6,680 Answers
Have a technician come out and clean the paper path and check the drum area, also the fuser the hot part
Posted on Jun 14, 2015
2 Suggested Answers
  • 286 Answers
SOURCE: How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Posted on Nov 07, 2008
I an getting light copies on konica minolta bizhub 362 what is the adjustment to make copis dark
Normally light copy comes out when mirrors are dirty. Before any adjustment clean the slit glass and mirrors.
Dec 17, 2012 | Konica Minolta Bizhub 362 Copier
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
My canon np6050 xerox machine doing darker copy . please tell me what can i do for it
just clean the optics mirror to clean those mirror remove the 2 screw in right portion of the machine the 2 screw is the lock of the metal plate in the right end portion of the platten glass the after you remove the screw remove the metal plate & platten glass then move the scanner assembly in the middle portion then you will see a mirrors wipe it with clean rugs then after you clean those mirror remove the 3 screw in the black cover inside the right portion of scanner after you nremove the 3 screw & the black cover you will see 2 mirror wipe it with clean rugs the after you clean the mirrors return all the cover you remove &the platten glass & metal plate then try to make a copy
Dec 08, 2010 | Canon Office Equipment & Supplies
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
My church has a HP Color Laser Jet 2840 someone came into the office and evidently pressed the scan button. The screen reads "Scanner error 5 turn off then on." I did this several times but it...
clean the glass, and if possible clean the underside.
At startup the scanner tries to define white. If you open the top and clean the under/otherside of the glass, you will see a strip of white labeling about 1/4" wide by the length of the scan area, this is the default white that the scanner uses to calibrate. Over time it gets dirty or spider webs get on it, clean it, but don't spray anything directly on it. Reassemble the top and power up.
Jan 02, 2018 | HP Office Equipment & Supplies
Copying on my 7210 hp all in one
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there. if you are using the flatbed portion of the scanner, clean the larger glass on the scanner and as before let it dry before trying to use the copier again and then test the copier.
Sep 18, 2008 | HP Officejet 7210 All-In-One InkJet...
Sends blank fax
Dirty scan glass
Clean slit of glass extremly well, it is a small slit rectangler section of glass before copy glass on the scanner.
Glue, Liquid paper are common finds on the glass in this area, While you have the lid up, clean white reference area (on lid directly on top of scan glass when lid is closed)
Feb 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
HP 7410 streaks on scanning and copying
First you need to determine if it's doing from both the  top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
Oct 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
26 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
