Question about Kitchen Ranges
Bosch hgs3052uc error code 125 - Kitchen Ranges
2 Suggested Answers
  • 457 Answers
SOURCE: bosch oven model HGS3052UC doesnt close tightly,
yesthis is a common problem with this brand. 2 things can be done. 1. replace the hinges left and right or add 3 washers on both sides of the hinge to bring the door hinges closer.Im a old bosch tech and I told them this was a issue.
Posted on Feb 26, 2010
C7 error code
C7 code has to do with your main fan. Either its not working due to it being blocked or having gotten wet/damaged/power surged, or your control unit isn't supplying the correct 120V to the fan. Your control has a ceramic fuse that you can test as well.
First, look for 120V to either the left or right pair of wires in the molex plug on the fan. if you have voltage, then the fan is bad. If you dont, its either just a fuse, the board is bad, or the fan is bad causing the fuse to blow. Insert the supplied spare fuse, and power up the unit. If it blows the fuse again, its the fan.
Mar 03, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
Oven does not heat but broiler does
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Mar 22, 2008 | Bosch HGS 255 Gas Kitchen Range
I have a Bosch AquaStar AQ-125-BNG tankless water heater, and for some reason when it is heating the water, it seems to get exremely hot and the heat is radiated back into the cold water supply line and...
Tankless should never be installed with plastic pipe, PVC or CPVC etc.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Error codes re: fan speed fan very noisy
I was looking for a service manual, which you apparently do not supply. I was not looking for someone who will charge me a fee to get information. I can get that info directly from Bosch for free. Thank you for answering. John
Feb 04, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch oven model HGS3052UC doesnt close tightly, hasn't since new 3 yrs ago. any idea how to fix?
Dec 27, 2009 | Bosch HGS3052U Gas Kitchen Range
Bosch sx250ng tankess water heater
1/ check overheat stat 2/ check fan esp the little flexie hose rear fan area for pinhole 3/check diaphrapm valve 4/ check micro switch best of luck
Sep 06, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
BOSCH RANGE HGS3052UC ERROR 160 AFTER REPLACING PANEL
f160 is cooling fan error
board not reading hall sensor on cooling fan
could be cooling fan not turning
hall sensor on end of motor not plugged in or hall sensor broken
Nov 24, 2017 | Bosch HES 232 / HES 236 Electric Kitchen...
Kitchen Ranges Logo
385 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
