Question about Pioneer AVH-P6500DVD Car DVD Player
How do i put my amp on this and i am not got no radio
    Problem Solver:
  • 11 Answers
You need a hideaway unit for amps etc
is the stereo uk or *** product where are you if you have bought it from another country it could be that your on a different frequency
if you need help tuning the board into your area email me sagar960@btinternet.com and ill send you detailed instruction hpow to do it really easy
Posted on Dec 04, 2008
Radio code
Yes please give me code on radio. Radio off press and hold 1 & 6 put radio on wait 3 second then release 1 & 6. Should flash 4 digit code
Jun 15, 2014 | 2009 Renault Trafic 1.9dCi
Pa
per fcc rules (laws)? you cannot put an amp on a cb. max output 4 amps. you should be able to put a pa speaker using the pa output jack. take your radio back for warranty.
May 19, 2013 | Cobra 19 DX IV CB Radio
Radio for 2002 Bentley Arnage T
Be sure to check fuses. You may have a blown fuse. If have the owner's manual, check for fuse block diagram and check for one listed as radio. If fuse is at fault, may have loose wire that caused it to blow.
Aug 12, 2012 | Bentley Arnage Cars & Trucks
What would it do to my navsure n420i car sat nav / radio if i put a 13 amp fuse in if it's a 10 amp radio
The fuse is made to protect a 10amp draw 13 amps will start burning wires you need to follow the specs if your 10amp is blowing then there is a circuit prob.
Jan 18, 2012 | Cars & Trucks
1996 mustang v6. the radio worked fine earlier
Stock headunnits are picky about the power they get, and when you are taking it to the headunit, it is putting unwanted strain on it. I can help more if I know where you put the fuse too.
Oct 10, 2009 | Car Audio & Video
PUT IN NEW STEREO NOW CAR WON'T START & SECURITY LIGHT IS ON
the radio that come with car is program to pcm .if remove or put in another radio. pcm security mode kick in.it dont recognize radio it think theft so it disable car ignition so you cant start.if you get a radio the dealership has to put them in and program it.
May 31, 2009 | 2001 Chevrolet Venture
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
My car radio dont work
I am sure that the radio fuse was checked to see if power is actually going to the radio? The next thing to check is the multipin plug on the back of the radio. If it was removed sometimes the pins get bent when plugged back in. Make sure all pins are clean and straight. Try to disconnect wires that were changed to install the amp and put everything back to original and see if the radio works. The amp should have a direct connection to the battery with its on fuse correct? Depending on the amp if new or used may have internal problems and will have to be sent back to the manufacturer for repair. Hopefully when the wiring is put back to normal in the vehicle the radio should work, unless the amp load has damaged the output transistors to the original radio. Good luck.
May 22, 2008 | JVC KD-G230 CD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
