Question about Canon Office Equipment & Supplies
My Canon PC 980 photocopier (black & white) is making a 1/4" dark line about 1" in from the entire left edge of each copy. Why and what do I do? Lars
  • larspi Sep 16, 2008
    Thanks, leroyal. I still have to call a repair tech, but at least I can sound somewhat knowledgeable and probably not get completely taken!
    Genius:
  • 2,120 Answers
It sounds like a bad drum cleaning blade.
Also lift open document feeder and check for wite-out in the glass.
Posted on Sep 16, 2008
Why is canon ir 3300 making dark lines on a copies please help
Did U check the drum? How many copies made?Can also be a transfer rolerr,or fixing film in heather
Aug 04, 2014 | Canon Ir 3300 Black & White Copier
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
My photocopier is printing black
Try removing the developer and reseat it.
Mar 09, 2011 | Canon NP 7130 Black and White Copier
Photocopies with black lines from top to bottom.
Try check your paper, see whether loaded properly or not.
If yes, probably u need to adjusting your casette
Feb 17, 2009 | Toshiba 1360 Black and White Copier
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
99 people viewed this question
old marine
old marine
