Daewoo TV Model DTQ 29S5SSF 29"
While TV was in operation heard a loud pop and television went dead. After removing back the first noticeable problem was a 22 gauge red wire leading from the circuit board to the picture tube in half. Appears a jolt of power shorted this wire and separated it in the center (of the wire). After stripping ends and reconnecting the wire, plugged it in and there was a soft "click, click, click" sound. Still no picture or sound. Any ideas? Is there a downloadable service manual available for this model? If so, what website do I go to?
  • rich medrano
    rich medrano May 11, 2010
    It would have to be a current surge to make that high voltage wire into a fuse. I haven't heard of a picture tube shorting out but that would explain it. The picture tube high voltage usually goes through the picture tube to ground. The clicking is the power supply not able to power up the high voltage circuitry after the power supply is ready to do so. There might be high voltage power supply issues and maybe shorted high voltage transformer. I can't find a schematic online either but I haven't been on the manufacturer's site. Did anything smell burnt? Any blackening around any components?
SOURCE: TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
Posted on Jan 14, 2009
jerryg50
  • 1673 Answers
SOURCE: Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Posted on Apr 26, 2009
techman
  • 3130 Answers
SOURCE: TOSHIBA PIP 29 INCHES OLD MODEL TV MODEL NO 2938
sounds like the vertical output IC and the filter capacitor in the vertical power supply.
Posted on Jul 07, 2009
SOURCE: need tv code to program remote for a standard TV; Daewoo model # DTQ-27S4FC
false
Posted on Nov 10, 2011
info2ukg
  • 11 Answers
SOURCE: i went sharp tv lc13s4 remote control service code
See the left side of tuner on pcb, you have got a micro switch. push the switch n get service menu.
Posted on Oct 27, 2012
Universal remote code for Daewoo Model #DTQ-27S4FC
Check these codes. These are setup codes for Daewoo TV with RCA-RCR311W remote control. 1004, 1011, 1025, 1056, 1078, 1085, 1087, 1103, 1123, 1132, 1205, 1208
Jun 25, 2012 | Daewoo DTQ-25S3FC 25" TV
My Daewoo Model DTQ-20U9SC no choices under TUNING
If they are grayed out means they are locked out---consult the owner manual to try to resolve this issue or GOOGLE THE MODEL NUMBER WITH "MANUAL" OR "PROBLEMS"
May 01, 2012 | Daewoo DTQ-20U9SC TV
I have a 13 inch Daewoo color TV model, DTQ-14P1FC I want to connect a Dvd player to it but I don't see any place on the back for video connection. Is there a way to connect a Dvd player to this t.v.?
you need rca connectors or hdmi connectors. if you only have the round cable tv style connector, you will need a modulator to connect to first
Jul 31, 2010 | Daewoo DTQ-14P1FC TV
Own a 52" panasonic rear projection tv. Heard a loud pop, and tv went out. Will not turn back on.
Power supply board is dead.Replaced power supply will solved this problem.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to replaced.
Feb 25, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
DAEWOO DCT 29 MF
Hi there!
You will have to source a remote. Without it there is no alternative. Regards, JUS004
Mar 19, 2008 | Daewoo DTQ-29S1FCN 27" TV
Daewoo Universal Codes for Comcast Remote
For Daewoo TV Model DTQ-27U4SC, try this for Comcast Universal Remote (one with the red select button):
1. Press TV button
2. Press Setup button until TV button blinks twice
3. Enter 10451
4. Press Power button (TV should turn off and is set)
Mar 01, 2008 | Daewoo DTQ-1440FC 13" TV
Popping sounds
Do a complete overhaul of the regulated power supply===solder any/all bad connects,replace any weak capacitors.HB Electronics kit #103-088 will help you locate which parts go bad===get on it before it crashes hard!
Sep 26, 2007 | Daewoo DTQ-27S3FC 27" TV
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
